Old 12-07-2020, 01:37 PM   #1
Mart
Mart's Avatar
Default Quick question re valve springs.
Hello!
Just a quickie.
If you have a valve spring with closely wound coils at one end only, should the end with the tightly wound coils go towards the guide, or the keeper??
Or does it not matter which way around they are fitted?
Thanks in advance.
Mart.
Old 12-07-2020, 02:20 PM   #2
Ronnieroadster
Ronnieroadster's Avatar
Default Re: Quick question re valve springs.
Mart the closely wound end of the spring goes towards the retainer/ keeper end.
Ronnieroadster
I use the F word a lot no not that word these words Flathead , Focus and Finish.
"Life Member of the Bonneville 200 MPH Club using a Ford Flathead block"
Owner , Builder, Driver of the First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921 in one and a half miles burning gasoline.
First ever gas burning Ford flathead powered roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH
Old 12-07-2020, 02:28 PM   #3
Mart
Mart's Avatar
Thanks Ronnie. I used 8 of these valve springs and got 7 the wrong way around!
Got a little rework to do!
Mart.
Old 12-07-2020, 06:29 PM   #4
Pete
Pete's Avatar
Ronnieroadster
Huh?
Old 12-07-2020, 07:44 PM   #5
Russ/40
Russ/40's Avatar
The tight wrapped coils go on the guide, or another description, against the block, or up.
Old 12-07-2020, 08:12 PM   #6
tubman
tubman's Avatar
I don't know about the rest of you, but I'm not sure of the answer yet.
Old 12-07-2020, 08:17 PM   #7
flatjack9
flatjack9's Avatar
I've always put the close would end to the guide. Less mass of the spring to control.
Old 12-07-2020, 08:30 PM   #8
JWL
Yes, the tight wound end goes up against the guide.
JWL is offline   Reply With Quote
Old 12-07-2020, 09:21 PM   #9
bbrocksr
Mart.
Looks like you got 7 right,Close coils go to the block.
Bill
bbrocksr is offline   Reply With Quote
Old 12-07-2020, 10:55 PM   #10
cadillac512
cadillac512's Avatar
Yes, close wound coils to the stationary end of the spring.
Terry
"It don't take but country smarts to solve the problem" (Smokey Yunick)
'41 Merc Town Sedan / 260" 8CM engine
'66 Fairlane four door / "warmed up" 302
cadillac512 is offline   Reply With Quote
Old 12-08-2020, 03:15 AM   #11
Mart
Mart's Avatar
Thanks for all the input, fellas. I'll go with the consensus.
Mart.
Old 12-08-2020, 10:11 AM   #12
JSeery
JSeery's Avatar
Mart.
Good decision!
