11-24-2019, 01:56 PM | #1 |
parts for tillotson
where can I get a rebuild kit for tillotson round bowl carburetor
11-24-2019, 02:01 PM | #2 |
Re: parts for tillotson
www.whidbeymodelaclub.com |
11-24-2019, 02:25 PM | #3 |
Check your private messages on this website.
Marshall |
11-24-2019, 03:18 PM | #4 |
Brattons and Snyders both offer rebuild kits for Tillotson carburetors .
11-25-2019, 11:38 AM | #5 |
The original post says "round bowl" Tillotson which I believe is the Model F1-B. The kits for the Model X and Model XF with rectangular bowl do not fit the round bowl Tillotson. I could use a kit for the early Model with round bowl also.
11-25-2019, 01:09 PM | #6 |
11-26-2019, 11:56 AM | #7 |
[QUOTE=f balsiger;1824829]where can I get a rebuild kit for tillotson round bowl carburetor (f1-B)
11-26-2019, 12:40 PM | #8 |
Do not know just where to get parts for your F1-B, but maybe some of these articles in Model A News (MAN), The Restorer (TR) or Model A Times (MAT) will help you out.
ERA CARBURETORS (NON-MODEL A) « The Marvel Rayfield R.I.F Carburetor » : MAN/64/2/30-32 (2017) “TIP…Parts to Revise Valve in a Tillotson”: TR/19/1/13 (1974) “That Funny, Square Bowled, No-name Carburetor (The Allstate Deluxe): TR/34/3/32 (1989) “Tillotson Carburetors”: TR/40/2/12-15 (1995) “TIP…Curing the Tillotson Drip”: TR/40/2/23 (1995) “Model A Era Carburetors (Non-Model A)”: TR/40/3/12-15 (1995) “Simmons Carburetors for the Model A”: TR/40/4/15-17 (1995) “Zenith Replica Carburetors”: TR/40/5/10-13 (1996) “(More of) Model A Era Carburetors”: TR/40/6/10-14 (1996) “TIP…Easy Carburetor Bolt Access”: TR/56/2/49 (2011) “NEW Tillotson Carburetors”: MAT/4/1/26-27 (2008) “Modern Weber Carburetor”: MAT/5/4/12-14 (2009) “Tillotson Carburator Repair Booklet”: MAT/6/4/7-8 (2010) “Mark Auto’s Tillotson Carburetor”: MAT/7/1/8-9 (2011) Pluck |
11-26-2019, 12:41 PM | #9 |
never mind see below. Thanks Flathead.
I know the voices aren't real but damn they have some good ideas! Last edited by redmodelt; 11-27-2019 at 12:10 AM. Reason: Updated my post. |
11-26-2019, 11:02 PM | #10 |
This has been asked before. Smith&Jones Model A Supply has a gasket set for this carb. Be sure the two halves of the carb body are flat where they meet so you get a good seal. These Zinc carbs are notorious for being warped. I think some Zenith parts will interchange but not the gaskets.
11-27-2019, 12:07 AM | #11 |
http://www.snjparts.com/Model-A-Carb...a-9502-tr.html
one of those gaskets should go in the recess under the bolt that holds the top and bottom together.
I know the voices aren't real but damn they have some good ideas! |
11-28-2019, 01:07 PM | #12 |
Sacramento Vintage Parts has Tilly parts
