Old 01-13-2018, 11:36 AM   #1
Jacksonlll
Jacksonlll's Avatar
Send a message via ICQ to Jacksonlll
Default Manifold Torque
I have been using 45 ft.# like the red book says. Page 1-134.
Someone said that this was wrong in the red book. They were listing all the errors in Les's book. They said it should be 25 to 30 ft.#.
What is correct????
Jacksonlll is offline   Reply With Quote
Old 01-13-2018, 11:46 AM   #2
Patrick L.
Patrick L.'s Avatar
Default Re: Manifold Torque
I think most folks like about 35#.
If yours is at 45#,it won't hurt a thing.
Old 01-13-2018, 12:00 PM   #3
Bill in NJ
I can remember in auto mechanics classes years ago a student ask the same question and the teacher replied to tighten it till it breaks off and then back off one half turn ! Some how I became an ASE master mechanic.
Bill in NJ is offline   Reply With Quote
Old 01-13-2018, 12:04 PM   #4
JOHN CT
JOHN CT's Avatar
I was told by a reputable engine builder, to torque to 20lbs. I looked at him cross eyed thinking he was crazy. So what can I lose I torque to 20 and everything is fine. Been 2 years now no leaks.
I’m happy
31 Tudor
66 Bonneville
57 Chevy pickup 27 T roadster pick up
JOHN CT is offline   Reply With Quote
Old 01-13-2018, 12:09 PM   #5
Purdy Swoft
Purdy Swoft's Avatar
Like Pat says 45 foot lbs. probably won't hurt .Ford didn't list torque settings , so I've been told . Over tightening is what warps the exhaust manifold . I just use a 3/8 ratchet and a deep wall socket with common sense . After a few heat and cool cycles check and retighten . repeat as needed untill it seems to hold . When the exhaust manifold warps, the outer ends curl outwards . The exhaust manafold has no outer studs and nuts to hold the the ends flat when over tightened . Just my thoughts and experience .
Old 01-13-2018, 01:03 PM   #6
Terry, NJ
Terry, NJ's Avatar
As Purdey says, Ford didn't list torque numbers, it was just reasonably tight! About 30-35 lbs. But very important, Re torque or tighten several times after replacing the manifold. Ford mod A s are good at loosening up the heads and manifolds. Over tightening at first is not a solution. Coming back several times and retightening is.
Terry
Terry, NJ is offline   Reply With Quote
Old 01-13-2018, 03:29 PM   #7
Purdy Swoft
Usualy when you retighten you will feel some minor looseness on some of the manifold nuts . After a few check and retighten they should settle in and hold . Most likely the manifold gaskets will shrink after a few heat cycles and retightenings . Its not about making it tighter each time. The manifold nuts just need to hold uniform tightness. Ford furnished a wtench that was used for head nuts & manifold nuts on one end , the other end fit the 3-X spark plug . The length of the mentioned wrench was supposeto give the proper leverage for the average person to tighten these nuts and spoark plug . This wrench ,came with the car.
Old 01-13-2018, 03:40 PM   #8
Roger V
Roger V's Avatar
I use 35 pounds and has worked well. There were some who used as high as 55 pounds. I think they were associating the size with head nuts which are working against compression. I agree that many statements in the "red' book are incorrect. Being in print makes it look official. One thing I stress is to tighten manifold nuts from the center outward and in stages. Nothing like trapping a bow and breaking the manifold to ruin your day. Of course you want the manifold to be on the same plane (flat, straight, etc.) as much as possible.
Roger V is offline   Reply With Quote
Old 01-13-2018, 03:53 PM   #9
Jacksonlll
Jacksonlll's Avatar
Thanks. That's a lot of good info. I'm a 35# person from now on.
Old 01-13-2018, 06:20 PM   #10
Brian T
Brian T's Avatar
We had a student in one of my classes that asked the teacher how many thousandths were there in an inch, the teacher replied, bloody hundreds of them.
Nothing can be made foolproof, ---- fools are ingenious bastards.
Brian T is offline   Reply With Quote
