Old 12-27-2021, 03:58 PM   #1
keviny
Default 1929 Model A truck
Hi, I just bought a basket case truck that needs alot of work. I am a woodworker and would love drawings of blocking, tops and any bracing. Does anyone have a source ?. I don't mind paying, just want to make the parts myself.
keviny is offline   Reply With Quote
Old 12-27-2021, 04:39 PM   #2
baba
Default Re: 1929 Model A truck
Is there enough left of the wood to make patterns?
baba is offline   Reply With Quote
Old 12-27-2021, 05:47 PM   #3
keviny
no, someone did a jackleg job of the cab blocks. I have one original door post that i can replicate. The top was not done well so I need to redo it.
Old 12-27-2021, 06:04 PM   #4
1930artdeco
1930artdeco's Avatar
Welcome to the club. You may end up buying the wood and then tweaking it to work. Sounds like you can replicate anything in wood but without a pattern to work from you may be stuck. You are luck there isn't much there. Where are you located? Someone may have one you can look at and make notes on. Join a club as well, more knowledge that way.
Mike
1930 TownSedan (Briggs)
1957 Country Sedan
Old 12-27-2021, 06:24 PM   #5
keviny
i am in Virginia. Trucks are few and far between. I guess I'll be visiting alot of antique car shows. I'll be visiting alot of antique car shows.
Old 12-27-2021, 06:50 PM   #6
keviny
Thanks so much for your reply's. I hope I didn't bite off more than I can chew. I've always wanted one of these trucks. It will keep me young learning what I need to know to restore this truck.
Old 12-27-2021, 07:06 PM   #7
GerryAllen
Kevin, join a local Model A club. It is amazing the knowledge and where to find "stuff" through the members
Gerry Birch Bay WA
GerryAllen is offline   Reply With Quote
Old 12-27-2021, 07:10 PM   #8
keviny
Thanks for the advice. I know there is a lot of knowledge to learn from.
