06-05-2016, 07:50 AM | #1 |
1934 Tudor Windows
Would anyone have a picture of the back window channel attached to the glass. I am using a vintique window kit and it needs to be cut down to work. Would like to be sure I am cutting in the correct place to allow it to work. I want the window to slide back and down like the factory. Thank you Gary
06-05-2016, 04:02 PM | #2 |
Re: 1934 Tudor Windows
This is one of the back windows intact. On the other side..I have taken out the window and the frame channel setup attached to the handle. The window back channel is still in the panel space but can be seen from on top. The panel is difficult to take off. I'll take a pic of the frame channel or measurements if that will help.
06-06-2016, 09:07 AM | #3 |
file size too big. here are the pics at a smaller size.
06-06-2016, 09:54 PM | #4 |
Have you seen this? I went off this to fix mine. The stop screw in the channel is off and the roll back pin on the bottom bracket is off. The sliders don't fit worth a darn either. I have pictures showing operation but cant find them, I'll keep looking.
06-06-2016, 10:22 PM | #5 |
Some other reading...
http://www.jalopyjournal.com/forum/t.../#post-2740182 |
06-06-2016, 10:41 PM | #6 |
http://www.fordbarn.com/forum/showth...indow+channels http://www.tagchips.com/CARS/34FORD/...NDOW_REGULATOR |
07-31-2016, 12:15 PM | #7 |
Thanks guys
