10-28-2021, 10:13 AM | #1 |
S.co.t question
What is the correct gear oil to use in a s.co.t supercharger?
10-28-2021, 10:46 AM | #2 |
Re: S.co.t question
If you will PM "PeterC" at the link BELOW, another FordBarn member that owns the beautiful, innocent-looking '35 3-Window coupe seen below, he 'll be able to tell you with authority what you need to know. Tell him that Coopman sent ya! https://www.fordbarn.com/forum/priva...o=newpm&u=2205 |
10-28-2021, 11:06 AM | #3 |
Re: S.co.t question
I use Lucus 85w-140 gear oil. There's only 3 bearings and two gears, nothing too complicated. Check every 1000 miles and keep the level where you can see it in the bottom of the reservoir/breather opening.
10-28-2021, 11:19 AM | #4 |
Re: S.co.t question
I would try to reach out to Ronnie Roadster. He has run one for years on his '32 and is one of the top experts regarding the rebuilding of these super chargers.
10-28-2021, 04:40 PM | #5 |
Re: S.co.t question
Hi Tim
What I use is a 90 weight synthetic gear lube this has worked perfectly in all of my Scot or Ital superchargers for many thousands of miles. The synthetic lube is what I recommend using for the many blowers I have built for others including GMC blowers. Remember to leave the gear case vent open so no pressure builds up in the case. Ronnieroadster
I use the F word a lot no not that word these words Flathead , Focus and Finish. "Life Member of the Bonneville 200 MPH Club using a Ford Flathead block" Owner , Builder, Driver of the First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921 in one and a half miles burning gasoline. First ever gas burning Ford flathead powered roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH |
10-28-2021, 05:44 PM | #6 |
Re: S.co.t question
10-28-2021, 06:06 PM | #7 |
Re: S.co.t question
I know who built it
10-28-2021, 07:36 PM | #8 | |
Re: S.co.t question
The rest of the car is beyond insane, too! DD Check-out some of the details like custom exhaust brackets. Finish is phenomenal. DD |
10-28-2021, 07:53 PM | #9 |
Re: S.co.t question
The one time I got eyeballs on PeterC's '35, they fell out and stayed that way for two days! They don't get any better, neater, cleaner or more detailed a custom job than that one!
-Jeff H Have you thought about supporting the Early Ford V-8 Foundation Museum? |
10-28-2021, 09:13 PM | #10 | |
Re: S.co.t question
One last one for now! DD |
10-28-2021, 11:40 PM | #11 |
Re: S.co.t question
Nice, indeed.
I dig coal, which provides motivation for EVs. |
10-29-2021, 10:48 AM | #12 |
Re: S.co.t question
10-29-2021, 01:18 PM | #13 | |
Re: S.co.t question
Zeke ....On any common old Ford, you are correct. Now (and since I don't know squat about Columbia rear ends and how they are plumbed), this car is equipped with a Columbia. Would that have anything to do with the cable's direction exiting the turtle? DD |
10-29-2021, 02:00 PM | #14 |
Re: S.co.t question
There is a switch for shifting the Columbia mounted just to the right of the radio head, and down at the bottom of dash panel which can be seen on Peter's car if you look carefully through the steering wheel. I believe that speedo cable is routed to that switch on the RIGHT side of car. But what do I know? DD |
10-29-2021, 04:51 PM | #15 |
Re: S.co.t question
Thanks Coop, that is a reasonable explanation.
10-30-2021, 02:21 PM | #16 |
Re: S.co.t question
Given how well that car is sorted out, I don't believe the turtle orientation was not purposely done, but who knows. The usual reason for strange alignment was when somebody shortens a torque tube and/or moves the radius arm mounts, they forget to align the turtle in the correct orientation. Have seen this issue multiple times!
10-31-2021, 03:47 PM | #17 |
Re: S.co.t question
Peter no longer owns this car...
10-31-2021, 05:08 PM | #18 |
Re: S.co.t question
That is true! Peter gave me a shot at it. That is one of the FINEST old Fords on the planet. Whoever the "early bird" was, he made a wise decision. That coupe will ALWAYS be known as "PeterC's" coupe! . |
10-31-2021, 05:09 PM | #19 |
Re: S.co.t question
I want to see what he does next!
10-31-2021, 05:29 PM | #20 |
Re: S.co.t question
Peter told me that he's selling his two Ford coupes to give himself more time to devote to his beautiful Mossport, big-block '66 coupe! His green '39 with early Caddy engine MIGHT still be available. DD
