Old 05-07-2010, 10:48 AM   #1
Dennis/CT
Cool Vibration in steering wheel
A while back I posted this same question. Now that the front end is rebuilt and aligned,I took my car for a test drive and found the vibration comes at higher RPM's just before you shift into 2nd gear and 3rd gear.Oil in trans is full,trans shift's good,rear mount's are new,have not checked the front mount,oop's. Could it be trans bearing's? I don't know when or if tranny has ever been worked on. Again it is a vibration not a shimmy or wobble. Thanks to all and lets have fun on the NEW BARN.
Dennis/CT is offline   Reply With Quote
Old 05-07-2010, 10:59 AM   #2
Tom Wesenberg
Tom Wesenberg's Avatar
Default Re: Vibration in steering wheel
Does it vibrate when you rev the engine in neutral?
Old 05-07-2010, 11:06 AM   #3
chet
Try running the engine revs up with the fan belt not on. Could be a problem with water pump or generator.
chet is offline   Reply With Quote
Old 05-07-2010, 11:10 AM   #4
Dennis/CT
Yes Tom it vibrates in neutral
Old 05-07-2010, 11:11 AM   #5
Dennis/CT
Thanks Chet I will try that
Old 05-07-2010, 11:15 AM   #6
Dennis/CT
OK I just found the correct button.Yes it vibrates in nuetral and I will try removeing the belt.Thanks Tom and Chet
Old 05-07-2010, 11:27 AM   #7
Dennis L Oberer
Does it vibrate in neutral and without the fan belt at certain speeds of the engine; especially when coming down from a higher rev? Look to the flywheel/pressure plate balance.
Dennis L Oberer
Green Bay WI
Dennis L Oberer is offline   Reply With Quote
Old 05-07-2010, 12:44 PM   #8
Jim Parker Toronto
Jim Parker Toronto's Avatar
Sorry, I don't have an answer for you, I'm just trying this new set-up out to see how to reply! Jim
Jim Parker Toronto is offline   Reply With Quote
