12-06-2016, 01:02 PM | #1 |
F-A-M Observation
Going through my Model A powered hot rod and replacing stuff. Pulled the engine and replaced the SBC rubber in the front B mounts. The 17 year old F-A-M rubber mounts were as hard as my ex-wife's heart! Ordered new rubber from Bert's. The new rubber biscuits 1-1/32" thick and the original biscuits were compressed unevenly and measured between 7/8" and 15/16".
I wonder if those that are having issues with F-A-M have considered the fact that they may need to replace the rubber.
No restorable Model A's were harmed in the building of this truck! |
12-06-2016, 02:00 PM | #2 |
Re: F-A-M Observation
Did you say Hot Rod ? You might wNt to try Hamb or another site! Wayne
12-06-2016, 02:16 PM | #3 |
I replaced mine this summer, I used nyloc nuts on the bolts through the biscuts so I could set the tightness for what worked best. The engine was the most smooth with them loose but made the clutch jumpy. I tightened them down a little at a time to find the best trade-off.
12-06-2016, 02:28 PM | #4 |
Bill W.
