12-06-2016, 10:53 AM | #1 |
rear axle key orientation
hello- i read all the posts on with many descriptions but no pictures- rear axle key orientation is said to be a cause of hub splitting and orietntion is often described as 'up' or 'down' but i have trouble understanding this.
so pls look at my rough sketch and tell me which is correct, fig 1 or fig2---it seems to me that the key contour ought to fit the groove rounded contour thank you |
12-06-2016, 11:41 AM | #2 |
Re: rear axle key orientation
12-06-2016, 03:21 PM | #3 |
'31 180A Last edited by tbirdtbird; 02-02-2017 at 11:28 PM. |
12-06-2016, 05:35 PM | #4 |
TIP#271: My key method, I put a small ding on each side of the keyway, lay the key with the radiused end, IN & DOWN, tap it in with the outer end sticking out over the threads, slightly. Put on the drum & tap the key in flush with axle shoulder. Then the washer & nut & torque to 105 Ft Lbs. After a week or so, I re-check the torque. NEVER use Loctite on the taper, "YOU'LL BE SORRY"!!!---Chief always sed, "YES, I'm SORRY, but I've lurned to LIVE with it"----LOL
Bill Tight
12-07-2016, 07:45 PM | #5 |
thanks to all - also thanks for putting up with my bad sketch- i had to do it as i could not understand verbal descriptions and could find no diagrams
12-07-2016, 08:17 PM | #6 |
'31 180A |
