12-06-2016, 09:53 AM | #21 |
Re: Headbolt washers!
In response to Mikeinnj's post above, I would like to add - a coolant leak in any cylinder will raise the temperature in that hole and will also clean house on the oily residue and the hard carbon deposits, all visible on the plugs and the top of the piston.
12-06-2016, 10:10 AM | #22 |
I have also seen the porcelain that surrounds the electrode on the spark plug get a hair line crack from firing in a cylinder that has a HG issue
12-06-2016, 10:28 AM | #23 | |
One problem with checking the washers for the grade is, they are already under the nuts and tight, somewhat. So, IF I decide to check for the Rockwell, I will just remove them all together. Also, just so there is no confusion, the Grade on a bolt is a shear strength test, not a pressure/smash/squash test. So, I think with all the opinions and conjecture I will just spool up that rusty hard drive and go with what I remember from my childhood and growing up with Model A's. Clean the radiator to make sure it is still good, maybe make a new water pump, toss a set of points in the distributor and reset the timing, and make this run like it should.
New owner of '28 Tudor Previously owned; '30 Sport Coupe '28 left brake ccPickup '31 SW Town Sedan '28 AA Stake Bed '30 Cabriolet '42 Super Deluxe 4door Sedan "If it don't fit, get a bigger hammer. If it breaks...... ya needed a new one anyway!!" Doing a good job here is like wetting your pants in a dark suit. It gives you a warm feeling, but nobody notices. Never pass up a bathroom Never neglect an erection Never trust a fart |
12-06-2016, 12:02 PM | #24 |
12-07-2016, 12:18 AM | #25 | |
the anti corrosion aspect of antifreeze would be a plus for you in my opinion. |
Thread Tools | |
Display Modes | |
