03-03-2015, 03:17 PM | #1 |
"B" motor crack
03-03-2015, 03:37 PM | #2 |
Re: "B" motor crack
Are you sure thats a crack?
Lawrie |
03-03-2015, 03:41 PM | #3 |
Re: "B" motor crack
03-03-2015, 03:42 PM | #4 |
Re: "B" motor crack
If it does ok now. I would not do anything with it.
03-03-2015, 04:55 PM | #5 |
Re: "B" motor crack
I'd double check as that isn't where cracks normally occur in a B block. Have you run the engine since acquiring the truck and if so was the exhaust free of moisture once the engine warmed up?
03-03-2015, 04:59 PM | #6 |
Re: "B" motor crack
03-03-2015, 07:26 PM | #7 |
Re: "B" motor crack
The parallel line to the right of the more obvious line supports the possibility of something like a crowbar being inserted to pry up the head. Keep your fingers crossed.
