10-11-2014, 05:39 PM | #1 |
Stripped Side bowl threads
The threads where the side bowl bolts to the carb top were pitted, well they finally gave way. Is it fixable? Helicoil! Braze and retap?????
10-11-2014, 06:03 PM | #2 |
Re: Stripped Side bowl threads
helicoil
'31 180A |
10-11-2014, 06:27 PM | #3 |
Helicoil, should be 1/2 X 20 TPI. Make sure you bolt the flat surface of the carb. to a angle plate and don't let that drill grab. JHHO.
10-11-2014, 09:26 PM | #4 |
Take a drill that is the correct size and grind most all the tip off just leaving enough flute to cut on the edge so it will act like a plunge cut end mill. You don't want to drill into the seat for the seal.
10-12-2014, 02:41 PM | #5 |
On a side bowl carburetor the bolt that holds the side bowl to the carburetor top does not seat the way a gas line with a ferrule seats on a non-side bowl carburetor. The gaskets on the side bowl do the seating and prevent gas leaks.
1931 160B & 1931 68B If you don't have time to do it right the 1st time, how do you have time to do it the 2nd time? |
10-12-2014, 04:54 PM | #6 |
10-12-2014, 06:30 PM | #7 |
Duh on me! Correct about the the sealing part! Still good advice for installing helicoil in non side bowl carb.
