02-20-2014, 10:23 PM | #1 |
Old style vs. Flathead Ted floaters.
I have never heard of the old style as shown in a previous thread. It looks very good to me and I am curious if their is any reason to go to Flathead's. The old style sure looks easy to install. I have no preference, just want the best. I have a frustrating brake problem with my Fordor. Any counsel is appreciated. Are Flathead Ted's just as easy to install?
Thanks Purdy Swoft for your answer to my PM.
Steve Hanna, Polk City, IA |
02-21-2014, 04:53 AM | #2 |
Re: Old style vs. Flathead Ted floaters.
I to had never herd of the old style floaters until now,so i don"t know how they work. I have the flathead ted"s on two cars, they are easy to install and work like disk brakes, be sure you order from flathead, his is the the best.
02-21-2014, 06:31 AM | #3 |
I would remove the old style floaters. There is a good risk of drum lockup while out driving. This occurs when things get a little worn and the floaters reverse.
02-21-2014, 11:19 AM | #4 |
The old brake floaters are just too simple for most. Usually if there is a way to ass up on brakes, people that don't know what they are doing will find it. People that don't know what they are doing will have the brakes poorly adjusted and try to getby with worn out lining and drums. What can you expect??? The vast majority don't know $hit about brakes and its a waste of time trying to help them.
02-21-2014, 02:07 PM | #5 |
They sure look simple to me and fool proof to boot. Routine maintenance should preclude any lock ups . I have new cast drums and understand the geometry involved. I do admire Ted's work and am willing to pay his price. He has earned it..I thought that the old way appeared to be simpler and quite reliable. I'll percolate this while considering all advise/suggestions.
THX
02-21-2014, 02:48 PM | #6 |
02-21-2014, 09:41 PM | #7 | |
02-21-2014, 10:48 PM | #8 |
Sure, you have my compliments.
02-22-2014, 02:17 PM | #9 |
Purdy, do the old brake floaters just work on the front brakes , or is there a different type for the rear brakes.
02-22-2014, 03:25 PM | #10 |
Yes the old style floaters only work on the front. I recommend Flathead Teds shoe centering pins for the rear. Look on page A-99, top of first column in the newest Snyders catalog. These square offset pins will make centering the rear brakes much easier.
02-22-2014, 03:32 PM | #11 |
I had a set of the old style floaters on a '29 phaeton I had once. They worked great on the car. However, the brakes squealed a lot when applied and I think they were the reason. I read somewhere that anything
loose within the brake drum/backing plate. Will vibrate when the brakes are applied which causes the squealing noise. The oblong steel plates used in the floaters were attached pretty loose if I remember correctly. Bob-A |
02-22-2014, 05:24 PM | #12 |
Well, I bit the bullet. I purchased the Deluxe brake energizer kit that Ted makes. A couple hundred bucks, but only a one time expense. Usually when I have gone on the cheap, I regret it later.
