Old 02-10-2014, 10:15 AM   #1
spinelll
spinelll's Avatar
Default Front Motor Mount
Is is possible to remove the front motor mount with the engine, crank pulley and radiator intact?
spinelll is offline   Reply With Quote
Old 02-10-2014, 10:26 AM   #2
larrys40
Default Re: Front Motor Mount
Yes,
Some cars are easier than others for a variety of reasons.....
you will have to remove the lower stud nut on the mount and washer & spring, remove the two 3/4" headed bolts & lockwashers holding the mount to the timing cover... and using a jack and block of wood on oil pan towards the front ( I like the front rail if you can get something up there) jack up the front of the engine very slowly/carefully until the stud clears. Do not jack up any more than absolutely necessary. check it often. You will have to keep the mount lifted and it will just clear. Of course if you have to replace your rear engine mount rubbers.. it can be done in the car..... but is made easier with a frame spreader and is of course much easier to do if you should ever have the engine out.
Be careful and observant and it can be done easily.
Larry Shepard
larrys40 is offline   Reply With Quote
Old 02-10-2014, 10:30 AM   #3
Al 29Tudor
Al 29Tudor's Avatar
I can't answer your question but use caution jacking up the engine. When I changed my timing gear many guys suggested loosening the engine mounting bolts before jacking the engine.
Al
Al 29Tudor is offline   Reply With Quote
Old 02-10-2014, 10:58 AM   #4
Jordan
Jordan's Avatar
don't forget to loosen the rear motor mounts or you could crack the bell housing.
Cowtown A's
Jordan is offline   Reply With Quote
Old 02-10-2014, 11:08 AM   #5
Jon
Jon's Avatar
Watch the clearance betw3een the firewall and the accelerator linkage also, if you lift the engine too high you can mash it into the firewall. Ya, Ya, don't ask how I know....
John - Kalamazoo, MI
Jon is offline   Reply With Quote
Old 02-10-2014, 01:09 PM   #6
Tom Wesenberg
Tom Wesenberg's Avatar
Also, if you have frame sag things will be much tighter for this job.
