Old 02-07-2014, 09:52 PM   #41
700rpm
700rpm's Avatar
Default Re: Antifreeze Leak Help!
Originally Posted by tbirdtbird View Post
if you decide to run plain water as someone suggested (here we go again) at least put rust inhibitor in there, else your block and rad. will fill up with rust in no time. Think cast iron rusts much? haha
Exactly right. Rust inhibitor. Good suggestion. A friend suggests a tablespoon of soluble oil. I haven't tried this yet. Maybe someone can verify this?
Ray Horton, Portland, OR
Old 02-07-2014, 10:15 PM   #42
flipp
flipp's Avatar
I've heard of this also. The tablespoon oil, the Rust inhibitor, and cool-aid… I don't know anymore!!
flipp is offline   Reply With Quote
Old 02-07-2014, 10:15 PM   #43
freak
freak's Avatar
Originally Posted by flipp View Post
Dang it!! I just got a called from Steve at Bert's and he said that he doesn't have the 2 Blade Cast Aluminum Fan in stock and that they probably won't get them until March!! I called all other reputable vendors I could think of and they all said they were backordered as well. :-/
The collector I purchased the car from gave it to me with antifreeze in it already. The car came from Colorado so I'm not sure if weather played a role in the decision to add antifreeze. It looks to be 50/50 though. But now that she's in California what do you suggest.. pure water?? I'm sure this question has been asked a million times on here.
Thanks again guys for your continues advice on my fix.
Snyder's shows it and doesn't say out of stock. Did you call them?
freak is offline   Reply With Quote
Old 02-07-2014, 10:49 PM   #44
Purdy Swoft
Purdy Swoft's Avatar
Antifreeze leaks in places that water won't leak. Antifreeze has a higher boiling point than water but that really doesn't help. A model A doesn't have to be running at 212 degrees to be running hot. The model A actually runs cooler with water. Some sing the praises of antifreeze fighting rust. Soluable oil or water pump lubricant will keep the system free of rust and help lubricate the pump at the same time . I use it for that reason. It will run cooler with straight water but you won't have rust protection. It takes more than a table spoon. I buy it in small bottles maybe 1/4 pint or thereabout. Different parts houses sell different brands. Gunk brand is lower cost here. Prices range from less than two dollars a bottle to just over five, depending on brand and who is running the parts store. If you have freezing temps you either need to use antifreeze or drain the system.
Old 02-07-2014, 11:15 PM   #45
700rpm
700rpm's Avatar
You and I are on the same page again, Purdy.
Old 02-07-2014, 11:42 PM   #46
Purdy Swoft
I think we usually are, Ray.
Old 02-08-2014, 05:42 AM   #47
flipp
flipp's Avatar
I did call. They are out of stock.
Old 02-08-2014, 05:52 AM   #48
flipp
flipp's Avatar
I agree. Thanks Purdy for your advice.
Old 02-08-2014, 05:59 AM   #49
flipp
flipp's Avatar
Go Team USA!!!
Old 02-09-2014, 11:04 PM   #50
RonC
RonC's Avatar
Where can I get this gasket sealer from?
I bought some at NAPA. Try this link
http://www.permatex.com/about-us/where-to-buy
RonC is offline   Reply With Quote
Old 02-10-2014, 12:29 PM   #51
jm29henry
jm29henry's Avatar
Flipp google ford model aparts suppliers a bunch will come up some one should have a new two blade here are few synders mikes affordable, macks antique auto parts ,smith and jones,gass light,brattons tams,and there are many more !!!!
jm29henry is offline   Reply With Quote
