01-13-2014, 08:16 PM | #1 |
Mitchell overdrive: 26% vs. 36%
I'm beginning the overhaul (rebuild) of my '29 150A (station wagon) chassis and have decided to install a Mitchell OD. The 36% version has been recommended to me. Any input as to this choice versus the 26% version would be appreciated.
Thanks for any comments. |
01-13-2014, 08:20 PM | #2 |
Re: Mitchell overdrive: 26% vs. 36%
I got 378s in the rear, and a Mitchel but I don't know what percentage
If it would have been a snake it would have bit ya! i can't spell my way out of a paper bag! |
01-13-2014, 09:02 PM | #3 |
I think you would be very happy with the 26%. I have 31 tudor with 3:27 , 26.7 Mitchell, inserted 65 hp motor, v8 pressure plate, 30 # off flywheel, web carb, brum 5.9 head, would not change anything except maybe 7.0 brum if it ever became ava. I can still take off from stop sign in 2nd gear just like she was still stock, with 2 people just a little touch more of throttle needs to be used. This is the way I wanted it to run. Loaned my car to X CUP GREAT RACE in 2003 , kids covered about 4500 miles and had 1 flat tire during motel time, they got 2nd place. Ken Davis the air condition man and his kids beat us out for first place. I would say get the 26% for your car, I run 62-65 most the time because I live next to I 10 interstate hiway. Have fun modelAtony tony white Lafayette,LA
01-13-2014, 09:47 PM | #4 |
I have 3.78 rear and 26% is plenty of OD.
01-13-2014, 10:05 PM | #5 |
I also have the standard Mitchell with 26%, and I think it is perfect for almost all uses. Anything much more than that is going to be too tall for some uses. As mine is, I cruise on the freeway at 60-65 mph very comfortably, and I still have my normal Model A gearing for around town. If you ever drive in hill country, 2nd OD is very useful too. I love my Mitchell and would not have a Model A without one.....
01-13-2014, 10:40 PM | #6 |
01-13-2014, 11:01 PM | #7 |
if you put a 36% in a model a it'll fall flat on it's face when put into overdrive. Most people use 26% for a reason. It's perfect for a model a
Cowtown A's |
01-14-2014, 12:18 AM | #8 |
I would absolutely NOT put a 36% in.... the 3.78 with the 26% is the way to go. If you really feel you want a ittle more I would go with a 3.54 which would give you a little more speed out of overdrive for general driving and then you have the 26% overdrive then as an option. Whoever recommended the 36% doesn't have enough experience with the engines and their power curve... at least for generally stock cars.
I Snyder H/C would be a good companion as well. Larry S. |
01-14-2014, 12:29 AM | #9 |
I have a 4:11 rear end with 36% Borg Warner and it's perfect. If you have a 3:54 or 3:78, and not a "built" engine, the 36% is too tall to have much use.
01-14-2014, 08:31 AM | #10 |
One nice thing about my 26% Mitchell is if I forget and come to a stop in "high range", the car will take-off quite smartly and I don't wake up until I hit high gear and realize then that I might want to take it out of high range!
01-14-2014, 03:13 PM | #11 |
Thanks Barners for the input on the Mitchell OD. Your info will help me make my choice
