Old 09-17-2020, 01:26 PM   #1
tshancock
tshancock's Avatar
Default Fuel gauge issue
I have a question. I have a 36 5 Window Coupe and the fuel gauge is not working. I have 6 volts at the sender. I also grounded the power wire on the top of the sender and watched the gauge to see if it moved and it did not. I'm thinking the gauge is bad. What about you?
tshancock is offline   Reply With Quote
Old 09-17-2020, 01:39 PM   #2
deuce lover
deuce lover's Avatar
Default Re: Fuel gauge issue
I'd test the gauge using alligator clips,wire and a 9V batt. Pulling the speedometer makes it easier to get to.
Old 09-17-2020, 03:10 PM   #3
JSeery
JSeery's Avatar
9v is a little severe, the normal test is with a 1 1/2 volt D cell.
Old 09-17-2020, 04:15 PM   #4
tshancock
tshancock's Avatar
Thank you gentleman I'll shall try it
Old 09-17-2020, 08:17 PM   #5
JSeery
JSeery's Avatar
The 1.5v comes from the Ford recommended test procedure and should give you a 1/2 scale reading on the guage.
Old 09-18-2020, 12:09 AM   #6
deuce lover
I guess I should have been more specific.The little 9V smoke detector batt will not hurt the gauge at all according to Lee Kelly in Idaho. .Its just a test to see if the needle moves.Lee used to do all my 6 to 12V conversions.Don't think he is no longer with us.
Old 09-18-2020, 07:19 AM   #7
Jacques1960
Jacques1960's Avatar
I’ve had to chase this problem myself. If the gauge itself is good and wiring to sending unit tests ok, then options may come down to clean (clean !) ground to tank itself or gas-logged cork or plastic float (they leak). The electro-mechanical aspects of the sending unit are pretty simple and not very prone to failure - the float itself, unless soldered brass, not so much.
Please let us know what you find
Jacques1960 is offline   Reply With Quote
Old 09-18-2020, 05:38 PM   #8
tshancock
tshancock's Avatar
Thank you
Old 10-02-2020, 02:24 PM   #9
tshancock
tshancock's Avatar
Found the problem. Sending unit is in sad shape along with the float having a couple of holes in it
