Old 09-17-2020, 04:42 PM   #1
DannL
DannL's Avatar
Default Starter windings . . . a Look-See
I don't know what I was expecting to see, but here's a look at the windings from a rebuild I'm attempting.
Not a Purist.
DannL is offline   Reply With Quote
Old 09-17-2020, 04:57 PM   #2
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Default Re: Starter windings . . . a Look-See
I thought you said this car was restored?
Honestly, what I am seeing is a starter that was overheated. Not sure if it was because of the lacquered cloth being old, -or from a 12 volt electrical source that overheated everything. Most everything is available in aftermarket for these things. You can likely rebuild it yourself.
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 09-17-2020, 06:10 PM   #3
Synchro909
Synchro909's Avatar
I've seen coils in a similar condition. I put it down to the cloth covering having rotted. It was very fragile. I had better on the shelf so I switched them but repair shouldn't be too difficult.
Old 09-17-2020, 07:04 PM   #4
David R.
Cloth friction tape to repair, don’t use plastic tape, then spray them good with electrical insulating varnish. I got a can at Grainger. Mine looked similar, not quite as bad. I also re insulated wire leads by braiding linen cord over frayed areas and then varnishing. I would show you but I can never get pictures on here.
David R. is offline   Reply With Quote
Old 09-18-2020, 10:17 AM   #5
Will N
Will N's Avatar
...or spend the $40 for a new set of coils that probably aren't shorted out...
Will N is offline   Reply With Quote
