09-17-2020, 01:26 PM | #1 |
Fuel gauge issue
I have a question. I have a 36 5 Window Coupe and the fuel gauge is not working. I have 6 volts at the sender. I also grounded the power wire on the top of the sender and watched the gauge to see if it moved and it did not. I'm thinking the gauge is bad. What about you?
09-17-2020, 01:39 PM | #2 |
Re: Fuel gauge issue
I'd test the gauge using alligator clips,wire and a 9V batt. Pulling the speedometer makes it easier to get to.
09-17-2020, 03:10 PM | #3 |
09-17-2020, 04:15 PM | #4 |
Thank you gentleman I'll shall try it
09-17-2020, 08:17 PM | #5 |
The 1.5v comes from the Ford recommended test procedure and should give you a 1/2 scale reading on the guage.
09-18-2020, 12:09 AM | #6 |
09-18-2020, 07:19 AM | #7 |
I’ve had to chase this problem myself. If the gauge itself is good and wiring to sending unit tests ok, then options may come down to clean (clean !) ground to tank itself or gas-logged cork or plastic float (they leak). The electro-mechanical aspects of the sending unit are pretty simple and not very prone to failure - the float itself, unless soldered brass, not so much.
Please let us know what you find |
09-18-2020, 05:38 PM | #8 |
Thank you
10-02-2020, 02:24 PM | #9 |
Found the problem. Sending unit is in sad shape along with the float having a couple of holes in it
