05-12-2018, 10:39 AM | #1 |
Picture of wires on Terminal block
Does anyone have a good picture of the way the wires go onto the terminal block bolts. Is there a nut at the base? My wires are quite tightly packed and I still can't get the cover on.
Tinbasher |
05-12-2018, 11:16 AM | #2 |
Re: Picture of wires on Terminal block
This diagram should help you.
Bob Bidonde |
05-12-2018, 11:57 AM | #3 |
Ignition conduit grommet is the biggest hangup. Might file the bottom edge of the cover a bit, but it should go on with downward pressure against the grommet.
05-12-2018, 12:06 PM | #4 |
Here is a picture of mine, FWIW
I do not have the large shielded cable that is part of the pop-out switch assembly. That is just a piece of loom cover you see. And the smooth black cable is for the temp gauge. Do you have a picture of yours?
Early '29 CCPU that had a 4-speed, but not any more.......in the family since '62 |
05-12-2018, 02:50 PM | #5 |
Well, red goes to coil +, unless you're running negative ground. Your red/black are reversed from the usual exit points.
Align the posts with the holes in the cover while holding it square-on. It's a tight fit - if it's cocked a little bit, it doesn't wanna go. Pull your temp gauge wire down too, of course. |
05-12-2018, 09:24 PM | #6 |
Tinbasher |
05-13-2018, 12:31 PM | #7 |
REMEMBER, the junction block is not mysterious, just a convenient place to join wires.
Bill Simple
05-13-2018, 07:56 PM | #8 | |
Bill Bad
Thread Tools | |
Display Modes | |
