10-22-2017, 01:25 PM | #1 |
window regulator rebuild
i was wondering if anyone has pictures of how the gear hosing go together? i had two . both were missing parts. im trying to make one but i want to make sure everything is right before i weld it back together . thanks for any help in advance . kyle
10-22-2017, 01:57 PM | #2 |
Re: window regulator rebuild
Does this help?
10-22-2017, 05:08 PM | #3 |
divcoone . no im looking for pics of how the gear plate s and springs go on the inside of the round hosing .its a fairly simple assembly but it does not hold the widow up. it keeps sliping down so i want to make sure the plates are in the right positions .thanks for the help though .kyle
10-22-2017, 07:59 PM | #4 |
I thought the part was rivited together , make sure the gears are the same on both regulators because I thought there was two different styles . Check the Snyders or Bratton parts books .
10-22-2017, 08:13 PM | #5 |
it would better if you showed which window regulator you are working on. there is four or five different ones in the Model A`s. |
