Old 03-14-2018, 05:09 PM   #1
firerod
Default 8ba fuel pump
I have a 8ba in a model A. The firewall is recessed for clearance, the stock glass bowl fuel pump won't clear the firewall. Did Ford make a 8ba pump with no glass bowl?
firerod is offline   Reply With Quote
Old 03-14-2018, 05:57 PM   #2
tubman
tubman's Avatar
Default Re: 8ba fuel pump
Have you tried "clocking" the bowl? You remove the 6 screws holding it together and then assembling the two parts in a position that will fit. There are earlier [pumps with no bowl that can probably be made to fit. It might take some mixin' and matchin' parts and a different pushrod, though. I have never had to do this so I don't know for sure.
Old 03-14-2018, 07:42 PM   #3
flatjack9
flatjack9's Avatar
Do as Tubman suggests.
Old 03-14-2018, 08:35 PM   #4
firerod
Never thought of that, thanks!
Old 03-14-2018, 08:41 PM   #5
Marvin/TN
Send a message via AIM to Marvin/TN
I think 34 didn't have a bowl. What ever is on my 46 does not have a bowl.
Marvin/TN is offline   Reply With Quote
Old 03-14-2018, 08:45 PM   #6
flatjack9
flatjack9's Avatar
I believe 46 was the first year that should have had the glass bowl. They were a universal replacement in years to come.
Old 03-15-2018, 12:44 AM   #7
flatheadmurre
flatheadmurre's Avatar
Since the diaphragm bolt pattern are the same you can use the lower part that fits the 8BA pumptower and the upper part from a pump without the glassbowl to.
There are non ford AC pumps with the glassbowl centered on top also as an option.
Old 03-15-2018, 09:38 AM   #8
RalphG
RalphG's Avatar
Yes, I remember my dad had one of those vertical bowl fuel pumps on the 52 Merc for a while. I've still got it but somebody damaged the threads on the fuel inlet.
RalphG is offline   Reply With Quote
