Old 02-12-2012, 03:16 PM   #1
JC60B
JC60B's Avatar
Default A6334 Brass thrust install
I am in the process of overhauling my engine and would like to use the rear A6334 Brass thrust/rear seal. I know that the original rear block thrust has to be removed for the install but that is about all the information I can find. Checked with Snyder's and they have no info on the install either and they sold it. I've read here members have installed them. What I'm looking for is detailed do's and don't of the install. For instance, does the cap rear thrust also have to be removed and what about the front thrusts? Thanks for any input.
JC60B is offline   Reply With Quote
Old 02-12-2012, 04:36 PM   #2
Brian T
Brian T's Avatar
Default Re: A6334 Brass thrust install
Hello JC60B,
I sent you a PM , I have just installed a 6334, It reduced the end play from .022 to .008, its an excellent fix as long as the rest of the babbit is OK.
Brian T is offline   Reply With Quote
