Old 09-22-2014, 09:43 AM   #21
svm99
Default Re: Mellings M15 Hi Volume Pump
Thanks for all the info, I'll put in my next swap meet load..................maybe somebody will want it for cheap! Paul J.
svm99 is offline   Reply With Quote
Old 09-22-2014, 10:21 AM   #22
JM 35 Sedan
JM 35 Sedan's Avatar
That's exactly what I did with one I bought 10 years ago by mistake. Fortunately for me, the motor gurus here and on the old MSN flathead Ford website advised me NOT to use this M15 in a FH street engine I was building at that time. I used an M19 pump that now has logged in ~ 25k trouble free miles. If they are junk, as someone mentioned, apparently I got a good one. I am putting a '36LB engine together now, and plan to use another M19 pump. Hopefully, I have another good one, as I do not think they are all junk.
John
Old 09-22-2014, 10:38 AM   #23
40's rule
Anybody use one of these yet https://www.bobdrake.com/ItemForm.aspx?Item=HR-6600-A what's your thoughts?
40's rule is offline   Reply With Quote
Old 09-22-2014, 11:59 AM   #24
JM 35 Sedan
The pump in that picture is what appears to be the same configuration as the Melling M-15. But then they call it a "short body" which I always thought was an M-19. Maybe they got their pictures mixed up.
John
Old 09-22-2014, 12:14 PM   #25
41ford1
41ford1's Avatar
That Drake unit is an M15. I have one on the shelf that measures the same.
You are never to old to enjoy your childhood.
Forty1fordpickup on the HAMB.
41ford1 is offline   Reply With Quote
Old 10-29-2014, 02:07 PM   #26
Ardun
Ardun's Avatar
Originally Posted by flatrod View Post
Would the M15 be worth using in a Ardun?
Yes for the M15 in an Ardun. It provides increased oil flow for the rocker arms and full flow filter. Do you have an Ardun?
Ardun is offline   Reply With Quote
