Old 12-23-2020, 10:19 AM   #1
Bob Bidonde
Bob Bidonde's Avatar
Default Never Tried To Restore
What are Model "A" Ford parts that you have not tried to restore because you consider them too hard to do, or technically too challenging?
In my case, I have not attempted to disassemble and restore a Houdaille Shock Absorber because I consider it too hard to disassemble. Another task I have not attempted is babbitting bearings because it requires special tools and know how.
Bob Bidonde
Old 12-23-2020, 10:35 AM   #2
Kurt in NJ
Kurt in NJ's Avatar
Default Re: Never Tried To Restore
I learned a long time ago that i could screw it up 3 times for what i would pay someone else to screw it up the first time
Old 12-23-2020, 11:06 AM   #3
JayJay
I'm with you, Bob - rebabbeting bearings is way beyond my skill and tool set. And regrinding crank and cam journals is something I will leave to the pros. I'm willing to attempt most anything else. The way I see it, someone put it together originally, and I ought to be able to figure out how to take it apart and put it back together with enough time.
Famous last words...
JayJay
JayJay
San Francisco Bay Area
1930 Murray Town Sedan
1931 Briggs S/W Town Sedan
Old 12-23-2020, 11:21 AM   #4
Cape Codder
Cape Codder's Avatar
I tried YEARS AGO to pour the Babbitt in a block with NO KNOWLEDGE of what I was doing. My neighbor was my assistant! He had NO KNOWLEDGE of what he was doing. Long story short when I poured the Molting Babbitt it BLEW UP and splashed in my neighbor's EYE! AMAZILY after a week with medication and patch on his eye his eye sight was fine. Two things I learned was apparently you need to pre-heat the block, and NEVER, NEVER attempt to do it again.
As to the shocks, I have taken several apart by heating them in a charcoal grill then dumping them in cold water. This is another experience of the hot meeting the cold so gloves, long shirt and safety glasses would be a must.
Those are my experiences of trying to RESTORE some parts!
Cape Codder is offline   Reply With Quote
Old 12-23-2020, 11:32 AM   #5
Terry, NJ
Terry, NJ's Avatar
If one man could make it, another can fix it. It's just a matter of how much effort and thought he's willing to put into it. For most of us it's not very much. It's easier to call Snyders. I am play around with nickel plating but I've got a lot to learn. Like how to produce nickel acetate in enough quantity to plate headlights or a bumper. How much of the old plating has to be removed?
Terry
Old 12-23-2020, 03:22 PM   #6
Oldbluoval
Oldbluoval's Avatar
Somebody on here has a great phrase
“Fix it till it’s broke”. Been there done that
Old 12-23-2020, 08:44 PM   #7
Big hammer
Speedometer mine hasn't needed fixing, generator sent it to Tom Wesenberg so he could do his magic!
get a bigger hammer tap done
Old 12-23-2020, 09:05 PM   #8
Ranchero50
My rear axle pinion was loose when I bought it. Luckily found a complete unit with 3.54's. I'll tackle just about any job but the rear looked like it would get expensive very quick and I hate setting up gears.
Building a '29 Speedster, the hard way...
Ranchero50 is offline   Reply With Quote
Old 12-23-2020, 09:48 PM   #9
Jack Shaft
I get the Houdailles apart.. but all I've found are junk.
Old 12-23-2020, 10:34 PM   #10
McMimmcs
McMimmcs's Avatar
Unfortunately we have not heard from Tom in a long time. A true gentleman and a master of the Model A.
Old 12-24-2020, 06:34 AM   #11
Chris in WNC
Chris in WNC's Avatar
Babbitt bearings & shock absorbers.
our next Model A is out there in the unknown......
Chris in WNC is offline   Reply With Quote
Old 12-24-2020, 06:50 AM   #12
Bob-A
Bob-A's Avatar
Smile Re: Never Tried To Restore
A 7-tooth steering gear was the hardest assembly I have restored. Shocks, babbit, & rear-ends are to complicated for me. Plus, the lack of proper tools.
Bob-A
Bob-A is offline   Reply With Quote
Old 12-24-2020, 08:27 AM   #13
Big hammer
Some where wondering how long his honey moon would last, enjoy your self Tom !
Old 12-24-2020, 09:49 AM   #14
Mike Peters
Mike Peters's Avatar
Things I can't do: 1. babbit bearings 2. Shocks 3. rewind armatures 4. soldering is beyond me 4. sew interiors 5. plating of any kind 6. recore radiators 7. machining heads, valves, etc. That's the short list.
Mike Peters is offline   Reply With Quote
Old 12-24-2020, 10:53 AM   #15
katy
katy's Avatar
I once saw a sign that said: "We can fix anything except a broken heart or a wallet"
Old 12-24-2020, 06:13 PM   #16
54vicky
54vicky's Avatar
he passed a while back in care.
54vicky is offline   Reply With Quote
Old 12-24-2020, 07:10 PM   #17
mleder
Mr. 54 Vicky, your comment about Tom is false, I spoke to him in the beginning of Dec., we live in the same city. Before you make a comment like that be sure of what you say.
mleder is offline   Reply With Quote
Old 12-25-2020, 12:28 AM   #18
SteveB31
SteveB31's Avatar
I have a friend who can rebuild and restore anything. He told me, anyone can do anything. You just have to have the desire, the patience, and be willing to get the tools needed to do the task. Any of you could do those things, you just have to really want to.
SteveB31 is offline   Reply With Quote
Old 12-25-2020, 01:12 AM   #19
Terry, NJ
Terry, NJ's Avatar
New Bearings and the gearset runs about $ 700. But it's the proper setting it up that is a PITA. You need a 3/8 torque wrench to measure the resistance, Too tight and it runs hot and burns out. Too loose and it will howl and wear out. Get a temp gun (About $40) and take the car for a short ride, say a mile out and a mile back. Then read the temp. On a warm day, It shouldn't exceed 200 deg.
Terry
Old 12-26-2020, 10:44 AM   #20
rocket1
B carb that is cracked at the inlet where someone over tightened the fuel line trying to stop a leak,resold it for parts at Hershey.
rocket1 is offline   Reply With Quote
