Old 02-27-2012, 07:16 AM   #1
bmita
Default hood question
is there any hood length size difference in the model A years? i have a 29 tudor sedan the hood i have doesnt fit the shell just right its like it is too short. i can bring the top of the shell in to meet, but the sides of the shell doesnt meet the hood. i was told the hood is off of a 29, but i dont really know other than it has a ridge running along it down by the hood sides. do i have the right hood or is this a four door hood? thanks
bmita is offline   Reply With Quote
Old 02-27-2012, 07:30 AM   #2
Barry B./ Ma.
Barry B./ Ma.'s Avatar
Default Re: hood question
Sounds like a fordor or cabriolet hood but it should be the same lenght as a std. 29 hood.
Barry B./ Ma. is offline   Reply With Quote
Old 02-27-2012, 07:57 AM   #3
RonC
RonC's Avatar
All hoods were the same for all models for all 28-29s and 30-31s
RonC is offline   Reply With Quote
Old 02-27-2012, 08:33 AM   #4
modelAtony
modelAtony's Avatar
I think early 28's different, 29 briggs,60 a-b-c-15b 1929 murry 1929 cabriolet were different than other 29 hoods. all others used same hood. all 1931 cars were the same have fun modelAtony lafayette,la
modelAtony is offline   Reply With Quote
Old 02-27-2012, 09:23 AM   #5
Tom Wesenberg
Tom Wesenberg's Avatar
When you say length, it sounds like you mean top to bottom, but I think of hood length as front to rear.
Old 02-27-2012, 10:02 AM   #6
RonC
RonC's Avatar
yes but aren't they dimensionally the same, 28-29 amd 30-31?
Old 02-27-2012, 10:04 AM   #7
Marco Tahtaras
Marco Tahtaras's Avatar
As said, it sounds like you have a Fordor/Cabriolet hood. However the fit would be the same as the only difference is the beltline a few inches above the hood side hinge.
Are the lower rear corners of the hood sides too close (opposite the front corners)? If not it sounds like a radiator issue. It's a long shot but it could be an early '30 "AA" commercial radiator. I photo of the back side of the radiator would tell.
http://www.abarnyard.com/
Marco Tahtaras is offline   Reply With Quote
