08-19-2012, 05:32 PM | #1 |
need some ideas on how to fix a hood hinge
on my model a sedan two of the center hood hinges broke away from the hood, has anybody ever had this happen? whats the best way to fix it. also one of the end center hinge broke off. any help would be appreciated.
08-19-2012, 06:42 PM | #2 |
Re: need some ideas on how to fix a hood hinge
separate hood pieces are available thru dealers, and good used hoods can be found at swap meets, repairing the hinges on the thin sheet metal rarely comes out good, and most of those problems are caused by a bent or rusty hood rod, buy a new one
08-19-2012, 08:55 PM | #3 |
Repro hoods don't always fit right. Try to find a good original. Bert's in Denver sometimes has some.
08-20-2012, 03:10 PM | #4 |
Hope this helps: J. Poole "The Old Tinbasher" |
