08-24-2021, 01:52 PM | #1 |
Drain Tube Length
What is the Oil Drain Tube Length supposed to be? I'm overthinking this, but while I have it apart I'm checking everything! My car is a '28.
08-25-2021, 12:12 PM | #2 |
Re: Drain Tube Length
Does this help? Source unknown.
08-25-2021, 12:29 PM | #3 |
08-25-2021, 03:29 PM | #4 |
Maybe it is just the camera angle BUT
1. A new repro drain tube measures 4 inches end to end with 1/4 inch of threads. 2. I measured 10 or 12 used main caps with drain tubes. They measure between 3 3/4 to 3 7/8 when installed and measured as in photo in post #2. Early '28 cars had 5/16ths tubes later cars used 3/8ths tubes Last edited by Benson; 08-25-2021 at 03:52 PM. |
08-25-2021, 03:56 PM | #5 |
08-25-2021, 06:22 PM | #6 |
"The more things change, the more they stay the same." |
08-27-2021, 05:35 PM | #7 |
More important than the length is to make sure the tube is not screwed so far into the cap as to block or partially block the tube . I ALWAYS notch the threaded tube end on the side opposite the dogleg to make sure its as open as possible. The tube is not a press fit- it is threaded into the cap. Nothing wrong with a dab of braze to keep it from unscrewing.
08-27-2021, 06:39 PM | #8 |
The thing is, don't try and braze it on a good running bearing, it will melt the Babbitt.
08-28-2021, 09:14 AM | #9 |
Good idea!
Thread Tools | |
Display Modes | |
