08-04-2021, 07:13 AM | #1 |
Another Main Bearing Question......
Sorry.....I have to learn somehow. I haven't gotten into the engine yet, but I assume that both the Main Bearings & Rod Caps have cotter pins? I have bought new ones because I'm sure it's best to change them out. What happens if after torquing the bolts/nuts down the hole doesn't line up for installation of the cotter pin? Do you loosen it or tighten it at that point? Am I worried about too many little things?
08-04-2021, 07:23 AM | #2 |
Re: Another Main Bearing Question......
Depends on how far off the alignment is off. If a half of a hole off, then just tighten. If too far off, just file a tad off the mating surface of the nut. Remember that any torque value that you are using are just a reference and are not absolute.
08-04-2021, 12:46 PM | #3 |
Cotters are cheap and should be replaced correctly. Torque wrenches weren't used when these monsters were made. Snug up the fasteners to what spec you want and then turn a bit more until the cotter drops in. If you need to take some off a nut, then you could try swapping nuts around, or, I sand them down using a piece of glass. |
