Old 01-22-2021, 04:08 PM   #1
rust revival
Default Transmission build, what will work
I have a complete 1937 #48 transmission
That came with a box full of parts as well
and 26H-7113 Cluster
26H-7017 Main Drive
06H-7102 Second Gear
And a complete 81A-7222 shifter housing with 3" fork
And 32 rear mount
My question what all can I use from the complete 37 trans to switch over
And what would need purchased.? Any book recommendations or manual
Thanks fellas
rust revival is offline   Reply With Quote
Old 01-22-2021, 04:23 PM   #2
cas3
Default Re: Transmission build, what will work
you need the book from Mac, Vanpelts sales
Old 01-22-2021, 04:29 PM   #3
petehoovie
petehoovie's Avatar
http://www.vanpeltsales.com/FH_web/f...trans-book.htm
Old 01-22-2021, 06:00 PM   #4
Juergen
Getting Van Pelt's book is great advice but it does not cover compatibility with 40's Zephyr gears. I got this information from and old pamphlet titled Gear and Torque by Jerry Hagens.
Prior to 1940 Lincoln Zephyr and Continental used the Ford gear set. In 1940 and 1941 both LZ and Continental used the so-called 26 tooth gears with the prefix 06H. From 42-48 they used a 25 tooth gear set with prefix 26H. Both sets used the 06H-7102 24 tooth second gear.
So if you have a 39 to 48 gear set in your 37 trans, you can use the 26H cluster and main drive and 06H second gear with a "39"gear set and appropriate washers and synchros and 81A shift housing with a 9!A- fork (not all 3 inch forks are 91A forks).
If you have a 37 gear set in your 48- case, only the first/reverse slider and reverse idler are compatible.
Juergen is offline   Reply With Quote
Old 01-22-2021, 06:05 PM   #5
deuce5wndw
deuce5wndw's Avatar
That is the Lincoln 25 tooth cluster and gear set. Don't know what you are putting that in but I wouldn't use that in a stock 37. Sell it for big bucks and buy a Ford gear set.
deuce5wndw is offline   Reply With Quote
Old 01-22-2021, 06:28 PM   #6
jimvette59
jimvette59's Avatar
The 1937, 48 case won't have the clearance for the Lincoln input shaft. Get a 78 case or I can sell you a Perfect 48 L/Z case with the factory clearance for those gears for150.00
email me for pictures. [email protected]
jimvette59 is offline   Reply With Quote
