Old 10-22-2017, 06:14 PM   #1
flat 39
flat 39's Avatar
Default Blown head gasket, water in oil
my 8BA started to overheat. The radiator looked empty so I put a gallon of water in. Hit the starter and the engine would not turn over. I pulled the plugs and hit the starter and water sprayed out of #4. I pulled the head and can see where the head gasket failed. I did not see any cracks anywhere. I pulled the dipstick and saw water in the oil.
The burning question is, Can a blown head gasket let water get into the oil or am I looking at something more serious?
Dick
flat 39 is offline   Reply With Quote
Old 10-22-2017, 07:22 PM   #2
zorro4153
Default Re: Blown head gasket, water in oil
Dick,
Yes, the water leaks past the head gasket in to the cylinder and then past the rings and into pan with the oil. Change the head gaskets and the oil and you should be good to go.
zorro4153 is offline   Reply With Quote
Old 10-22-2017, 10:15 PM   #3
slowforty
slowforty's Avatar
Use a composite head Gasket.They seem to seal better than the copper ones. I got mine from Speedway.
slowforty is offline   Reply With Quote
Old 10-23-2017, 07:40 AM   #4
chap52
chap52's Avatar
If your not pulling the pan I would suggest that you leave the drain plug off of the pan while you work on the top end so that any water in the lower end has a chance to dry out. I have to tape a note to the steering wheel or put the drain plug next to the oil I will be refilling with, reminding me to replace the plug before filling with oil. (Don't ask!)
Also I would coat the cylinder walls with a light coat of motor oil, (like greasing a cake pan pan)before I put the head on.
Is it a big hassle to change both head gaskets while your there?
chap52 is offline   Reply With Quote
Old 10-23-2017, 08:33 AM   #5
Frank Miller
Frank Miller's Avatar
Check to make sure head is not warped.
“The technique of infamy is to start two lies at once and get people arguing heatedly over which is true.” ~ Ezra Pound
Frank Miller is offline   Reply With Quote
Old 10-23-2017, 08:58 AM   #6
JWL
Some good suggestions here. I would want to check for damage from the hydraulic lock. A bent rod is not uncommon in situations like this.
JWL is offline   Reply With Quote
Old 10-23-2017, 09:09 AM   #7
flat 39
flat 39's Avatar
JWL, The rod does not appear to be bent as the piston goes all the way to the top.
