Old 03-21-2017, 07:13 PM   #1
Veeder
Default Heater Hot Water Control Valve V-8 1941 -Call me Crazy
ok I'm ticked off at Mac's -They Claim to sell a replacement Hot water control valve as a direct replacement....... I contacted them with little ...... but I think the pic is worth a thousand words.
I took one of their (Macs) valves and modified it to replace the original.
If I'm wrong please someone straighten me out but in my opinion the valve I had on the car was original and the valve Macs sells cannot be installed correctly.
I guess this just gives me something to &&&&& about LOL
Veeder is offline   Reply With Quote
Old 03-21-2017, 07:27 PM   #2
Newc
Newc's Avatar
Default Re: Heater Hot Water Control Valve V-8 1941 -Call me Crazy
Hi; Same with the NAPA valve. I use the new stem in the old valve bodies. Newc
Old 03-21-2017, 07:33 PM   #3
Veeder
I would have done that and looked at it closely but the body area where the stem screws in was slightly crushed would have taken way to much effort to salavage the original between the crushed threaded area and rust the body was to far gone
Old 03-21-2017, 08:01 PM   #4
paul2748
paul2748's Avatar
I had the same type of thing from Mac's. I bought what I thought was a reproduction but was not. Bought the piece from Carpenter which was correct
48 Ford Conv
56 Tbird
54 Ford Victoria
Old 03-21-2017, 09:25 PM   #5
Veeder
I believe they (Carpenter) are selling the wrong valve as well maybe you got lucky
http://dennis-carpenter.com/hot-wate...e/p/91a-15142/
Old 03-22-2017, 08:26 AM   #6
Kube
Kube's Avatar
You are not incorrect. No one sells the correct valve as a reproduction.
