Old 07-28-2015, 07:04 PM   #1
WestCoast
Default 42 ford p/u
where can I find the vin number on a 42 ford p/u
WestCoast is offline   Reply With Quote
Old 07-28-2015, 07:19 PM   #2
JSeery
JSeery's Avatar
Default Re: 42 ford p/u
Same place as normal. VanPelt is a good source.
http://www.vanpeltsales.com/FH_web/f...ialnumbers.htm
From 1932 through 1948 vehicles, Ford Motor Company stamped the serial number into the top of the driver's side frame rail in three locations. This same number was also stamped into the top of the transmission-to-engine housing portion of the transmission. This location was visible when the floorboard and transmission cover plate were removed. Of the frame-stamped serial numbers, only the forward-most stamping was visible when looking down into the engine compartment (located between the front crossmember and the dash (firewall). The two other frame locations are visible only when the body is removed from the frame. The serial numbers were metal stamped with numbers/letters approximately 1/4" in height.
Old 07-28-2015, 07:30 PM   #3
Ken Crans
Ken Crans's Avatar
Should be on the top of framerail by the steering box.
Ken Crans is offline   Reply With Quote
Old 07-28-2015, 08:11 PM   #4
Mike B
Yes, as Ken says...do a tad of wire brushing, mines quite legible
Mike B is offline   Reply With Quote
