Old 02-06-2015, 02:35 PM   #1
dodgeo
dodgeo's Avatar
Default 1936 Grilles
I've been told that the deluxe grille had the vertical bars satin chromed and
then welded into place while the standard one was stamped from one piece
of steel. When restoring a deluxe car would it not be better and cheaper to
chrome a one piece grille?
Am I on the right track with this?
dodgeo is offline   Reply With Quote
Old 02-06-2015, 05:31 PM   #2
TagMan
Default Re: 1936 Grilles
Whoever told you the vertical bars were chromed and then welded, has never welded, I'll bet. Attempting to weld on chromed parts would surely destroy the chrome.
I also don't believe that any '36 Fords came out of the factory with one-piece, stamped grilles.
TagMan is offline   Reply With Quote
Old 02-06-2015, 05:33 PM   #3
thirt4
thirt4's Avatar
I know that in 1934, Ford stamped their grilles and nowadays you can spot an aftermarket because they were welded then chromed.
thirt4 is offline   Reply With Quote
Old 02-06-2015, 06:11 PM   #4
deuce lover
deuce lover's Avatar
Ford did have 1 piece stamped grilles in 36.They are hard to find.I sold one about 6 mo ago that came out of my 5W coupe.
Old 02-06-2015, 08:34 PM   #5
Gary Tosel
Gary Tosel's Avatar
I have a one piece stamped grille that was painted and not chrome on my 36 Ford 5W Coupe. I have a friend with the same one piece stamped grille that was chromed originally and then rechromed for restoration.
Gary Tosel is offline   Reply With Quote
Old 02-06-2015, 09:49 PM   #6
DavidG
DavidG's Avatar
The one-piece original grilles are around and they do plate or re-plate better, at least in theory.
