Go Back   The Ford Barn > To The Editors > Questions & Suggestions
Old 06-24-2010, 09:40 AM   #1
cdan34
cdan34's Avatar
Default Columbia freeze
I was on my way to the L.A Roadster show with my '34 Cabriolet and 55 mi out, what I believe, was the rear end locked up, fortunately I got over to the side of the hwy and was trailered home ok. Before leaving the oil level was checked. It was bulletproofed and had pull out axels with bearing retainer on backing plate. This set up had about 7000 mi. on it and ran great. Before I tear into this I'd like to know if anyone has had this problem with the Columbia ?
cdan34
cdan34 is offline   Reply With Quote
Old 06-24-2010, 11:45 PM   #2
Lanny
Lanny's Avatar
Default Re: Columbia freeze
cdan34
Just a note to say, you are in the "Questions & Suggestions" section, which is more for questions about This FordBarn site.
I think you will get more responce in the "General Discussion" forum, and look for the "Early V/8" section for help. Good Luck......
If mama ain't happy, ain't nobody happy.
But if daddy ain't happy...RUN
Lanny is offline   Reply With Quote
