05-16-2016, 04:47 PM | #1 |
Lower hose leaks at heater connection
I got all the wiring done today except for the dash assembly. New Cokers mounted and balanced on wheels. Figured out how to install the seatbelts. Queen Mary horns in and working. I fired up the motor, listened to it purr, shut it down after 5 minutes and noticed antifreeze on the floor, coming from the heater hose nipple on the lower hose. It was leaking around the concave metal part that is on the outside of the lower hose. I need some advice on how tight is good for that niple connector. Maybe I wound it on too tight and caused a hole at the inside corner? Should I goop in some RTF or something else when installing it? I'll test it tomorrow after removing the hose and examining it. Not my favorite piece of hose to work with. Thanks for any suggestions.
05-16-2016, 04:58 PM | #2 |
Re: Lower hose leaks at heater connection
When I install that hose fitting, I make sure the punched hole is snug on the pipe & use #2 Permatex on the underside plate & nipple.
Works for me. |
05-16-2016, 05:45 PM | #3 |
The hole needs to be cut clean, slightly smaller than the pipe
there is a tool for cutting the hole, baisically a piece of dowell with a nail for the center, and a blade like xacto screwed to the side ---done this way I have not had any leaks perhaps you can back off the outer nut and put some permatex under the plate |
05-17-2016, 05:48 AM | #4 |
I had leak at that fitting also, statically. I took a 5/8 od steel tube and butt-welded it to a piece of leftover steel tube from the upper radiator hose, so it is "T" shaped. Then I drilled out the hole so water would flow. I split the lower hose in two and installed it with a short stub on either end of the steel "T". 'Had to do the same on the upper heater hose as well because I could not find the right fittings to attach to the waterpump.
05-17-2016, 02:06 PM | #5 |
I installed one on the 48 recently. I used #2 Permatex on the inside piece and made the hole in the hose with a short 3/8" pipe nipple ground down sharp on the end. It made a snug hole and it hasn't leaked yet.
How do you like your new Cokers? Did you use rim strips? |
05-17-2016, 04:22 PM | #6 |
Darrell, no I did not use liners, didn't realize they existed for 16" wheels as they do for 19's and 21's in the Model A world. Coker didn't have standard bias ply tubes so sent along radial tire tubes that look much more heavy duty that the standard ones. According to Coker, running radial tubes in bias ply tires is OK but no the reverse. The tires are mounted but the car isn't ready for them to be on the hubs quite yet. They seem good, time will tell. |
05-17-2016, 05:25 PM | #7 |
The reason I asked about the rim strips is because Old Henry said in one of his posts he has had no more flat trouble since installing the strips. I know there has been problems with the valve stems parting company with the tubes. I"m about ready to put new tires on myself so was wondering. I didn't know about the radial tubes, learned something new again. Good luck and have fun driving the old Ford.
