02-27-2016, 09:51 PM | #1 |
Orwell health heater door
I have a Otwell health heater and I was wondering if I'm missing a spring on the top bolt to hold the door and deflector tight? Here is a pic. of the door. It was on my car with just the 2 bolts holding it on and the door was hard to move with the top bolt tightened.
02-28-2016, 08:31 AM | #2 |
Re: Orwell health heater door
Yes. I think(car isn't handy to look at) I used a longer bolt and nut to secure the housing, the extra length for a spring,door,and deflector. The door and deflector now stays put. I think I used a locking nut keeping tension on the spring, door, and deflector.
02-28-2016, 09:38 AM | #3 | |
02-28-2016, 11:00 AM | #4 |
Mine is an all-original, and it too has a spring. I think the consensuses is that you do need a spring.
02-28-2016, 10:46 PM | #5 |
Thanks guys for your help
02-29-2016, 06:19 PM | #6 |
Re: Otwell health heater door
The screw is a shoulder type so that it "bottoms out" in the threads cut in the top mounting hole. Then there is a lockwasher and nut on back (engine side) of fire wall to keep it tight. Last edited by Benson; 02-29-2016 at 06:24 PM. |
