05-23-2014, 10:05 AM | #41 |
Re: Old problem revisited, rough running 8BA
05-23-2014, 11:40 AM | #42 |
I think some one put that chevy dist in and you didn,t know it.
Last week it was a Mallory. Some times a backpack will chock off your brain. |
05-23-2014, 01:11 PM | #43 |
05-26-2014, 12:08 AM | #44 |
I have used a dual point dist on a 53 Ford. Two suggestions: Sticking valves - try MMO down carb Venturi and two dist cap cracked or contains moisture. I have experienced all of these conditions - result is rough engine.
05-26-2014, 01:40 AM | #45 |
I had a similar problem with my 8BA (Max1,390 Holley). After checking with Mallory tech support I was told to use their promaster E-Coil (30440) even though the mallory web site showed another unit. Mallory told me the 50227502 electronic distrubutor was breaking down my coil. I bought the promaster and the problem disappeared. Pulls strong to 5000 without a misfire
3 pedals, 3 gears, no valve-covers.. Now THAT is a hot rod !! https://www.youtube.com/watch?v=ZmwwB34vxJE |
05-26-2014, 12:24 PM | #46 | |
