Old 01-10-2021, 06:07 PM   #1
30blindback
Default Paint v/s Japaning
Need advice on painting my carburetor or japanning. I also need a good recipe for japaning. What the most accurate?
Jon Harris
Portland, Maine.
30blindback is offline   Reply With Quote
Old 01-10-2021, 09:01 PM   #2
Doug Linden
Doug Linden's Avatar
Default Re: Paint v/s Japaning
In the Nov-Dec 2019 issue of The Restorer magazine there was a good article on how to make you own Japan Black Enamel and how to apply it to the carburetor.
Doug Linden is offline   Reply With Quote
Old 01-10-2021, 09:28 PM   #3
Ranchero50
I had some wood stove black polish that I put on my short term Zenith B and it's holding up surprisingly well. Just food for thought.
Building a '29 Speedster, the hard way...
Ranchero50 is offline   Reply With Quote
Old 01-11-2021, 09:28 AM   #4
Bob Bidonde
Bob Bidonde's Avatar
Japanning is a lot of work. Check this site:
https://www.plane-dealer.com/single-...tuff-japanning
Bob Bidonde
Old 01-11-2021, 09:46 AM   #5
31 Woody
31 Woody's Avatar
Very interesting. I hadn’t heard of this process or forgot I did, but the article was an interesting read. I would kind of like to try this.
Experience is a cruel teacher. It gives the exam first, then the lesson.
31 Woody is offline   Reply With Quote
Old 01-11-2021, 12:31 PM   #6
Jim Mason
Jim Mason's Avatar
http://jmodela.coffeecup.com/japan_black.html
www.jmodela.coffeecup.com
Fwiw, jm.
Jim Mason is offline   Reply With Quote
Old 01-11-2021, 12:39 PM   #7
Jim Mason
Jim Mason's Avatar
You will need to add a flattening agent (rosin) to knock down the gloss.
Fwiw, jm.
Old 01-11-2021, 01:48 PM   #8
30blindback
Thanks for all the responses. I will research the article in the restorer for the recipe. I want a durable finish that won't wash off with gasoline.
Jon Harris
Portland, Maine.
Old 01-11-2021, 10:17 PM   #9
1crosscut
1crosscut's Avatar
This is what I use on my carburetors. Leaves a glossy finish rather than a a more matt one as original but it holds up really well against gasoline.
A couple of coats of the high heat paint, let it cure for a couple days then a couple light coats of the clear fuel proof LustreKote. Hobby Town carries the clear.
Dave / Lincoln Nebraska
1crosscut is offline   Reply With Quote
