Old 02-03-2019, 12:01 PM   #1
dbaldwi3
dbaldwi3's Avatar
Default Oil pan baffle
Before I damage the oil pan is there a preferred way to remove the oil pan baffle so as to clean out the sludge from below? In the book it simply states remove baffle. Also as a side note the previous owner used a bolt with a lock nut to hold oil pump in place as far as I can tell the damage was limited to damaging the threads on the bolt, no cracks in block thankfully. I will replace it with the correct pipe thread plug. Thanks in advance for any information!
dbaldwi3 is offline   Reply With Quote
Old 02-03-2019, 12:04 PM   #2
1crosscut
1crosscut's Avatar
Default Re: Oil pan baffle
Place the pan on the floor and put a baseball bat or such in the hole where the oil pump goes through. Use it to pry/pop the baffle out. It is a friction fit with small indents along the sides.
Dave / Lincoln Nebraska
1crosscut is offline   Reply With Quote
Old 02-03-2019, 12:14 PM   #3
dbaldwi3
dbaldwi3's Avatar
Thanks Dave! took a lot more force than I anticipated but I got it. amazing how much sludge was in pan bottom!
Old 02-03-2019, 12:42 PM   #4
Y-Blockhead
Y-Blockhead's Avatar
I find it amazing how many people put a bolt in that plug hole to "hold the oil pump". A local 'machinist' did that to my block (among other things I wasn't thrilled about) that I had main bearings installed in . No doubt I won't be using them again.
Old 02-03-2019, 12:46 PM   #5
aermotor
Don't do like I did. Installed the pan with nice new gaskets and seals then went to the shelf where the oil was stored and found the baffle sitting on top of the case of oil.
John
aermotor is offline   Reply With Quote
Old 02-03-2019, 01:03 PM   #6
AL in NY
AL in NY's Avatar
Easiest way I have found to remove the baffle without damaging the oil pan is to drop it from about six or seven feet onto dirt and grass covered ground so it lands flat on the gasket surface. The baffle usually pops out on the first or second drop.
AL in NY
AL in NY is offline   Reply With Quote
Old 02-03-2019, 01:07 PM   #7
michael a
michael a's Avatar
X2 on the drop
Sent from my SM-J701M using Tapatalk
michael a is offline   Reply With Quote
Old 02-03-2019, 01:15 PM   #8
v8fordman
v8fordman's Avatar
Agree with the drop and then I don't break all of my childhood baseball bats.
v8fordman is online now   Reply With Quote
Old 02-03-2019, 01:47 PM   #9
Kurt in NJ
Kurt in NJ's Avatar
Dropping can bend gasket flange, bat-rod-pipe-prybar, catch other side of pan under lift--step ledge, running board to hold pan secure and reduce the mess
Old 02-03-2019, 02:08 PM   #10
dbaldwi3
dbaldwi3's Avatar
Thanks for all the replies and advice. After getting the baffle out and cleaning up all the sludge I’ve moved onto disassembling the oil pump which was in remarkably good shape bushings and all. The plan is to reassemble everything back into car tomorrow.
Old 02-03-2019, 02:20 PM   #11
Joe K
Joe K's Avatar
Now that you've removed the sludge, you sort of get a choice to go back with original non-detergent oil and continue periodically cleaning the pan, or detergent oil in your grade/viscosity.
Keep in mind the oil galleries and valve chamber are not cleaned - detergent oil in this area will eventually lift the sludge from there and everywhere else to end up IN your oil or at least a thinner coating of sludge on the motor interior generally. That is the point of detergent oil.
After converting to detergent oil (should you go this way) 3 changes of oil at usual intervals will mostly clean out the rest of the engine to where you need not worry.
Or, forgo a change. You can continue to drop that pan. It works.
There are adherents to both theories of operation.
Joe K
Shudda kept the horse.
Old 02-03-2019, 02:52 PM   #12
AL in NY
AL in NY's Avatar
Kurt in NJ: You won't bend the gasket flange if you drop the oil pan on soft ground, not asphalt or cement.
AL in NY
Old 02-03-2019, 06:31 PM   #13
1crosscut
1crosscut's Avatar
Dropping the pan works well but can make one hell of a mess.
Old 02-03-2019, 08:00 PM   #14
160B
160B's Avatar
and do not have a oil/sludge mess that you can get by dropping
1931 160B & 1931 68B
If you don't have time to do it right the 1st time, how do you have time to do it the 2nd time?
160B is offline   Reply With Quote
Old 02-04-2019, 09:12 PM   #15
KGBnut
KGBnut's Avatar
I know that you already got it out, but I thought I would share my technique. I put a board across the open pan, then slip a big C clamp alongside and under the baffle. I then gently screw in the clamp, pulling the baffle toward the board until it pops out. It has the advantage to being slow and gentle, without the risk of damage.
Ken
Style beats speed any day, and with a lot fewer tickets.
KGBnut is offline   Reply With Quote
Old 02-04-2019, 10:35 PM   #16
1crosscut
1crosscut's Avatar
Ken
Nice! I like that.
Old 02-04-2019, 10:53 PM   #17
Kurt in NJ
Kurt in NJ's Avatar
But the stuff that comes out the bottom of the pan can be quite toxic----pollute the ground, runoff into streams---not to say it is hard to clean off the face too---I have seen the results
Old 02-05-2019, 10:45 AM   #18
Purdy Swoft
Purdy Swoft's Avatar
The sludge killed the grass for quite a while where I dropped the last oil pan that I did . What should be done with the sludge ? If the sludge is put in some sort of container , it will more than likely eventually make its way to the ground when the container fails . If the sludge is burned , the smoke will pollute the air , It is just a messy job ..
Old 02-05-2019, 11:09 AM   #19
katy
katy's Avatar
I would put it in the used oil that goes for recycling.
Old 02-05-2019, 07:52 PM   #20
dbaldwi3
dbaldwi3's Avatar
Agree! I scraped it into the oil drain pan along with the used oil then funneled it into oil jug for recycling.
