Old 02-28-2016, 05:10 PM   #1
CSArno
CSArno's Avatar
Default '49 F1 back on the road!
Took the '49 F1 out for its maiden voyage on the road today as its new owner. had 3 generations of us in the cab. My Dad, me and my son.
goes and stops really well. Has a bit of a death shake when you hit a bump in the road. tierod ends and swing arm are tight. pretty sure its the steering box. I had already adjusted it as far as it would go. looking like a rebuild for that. still needs an exhaust, was just running some straight pipe off the headers have some Smittys glass packs for it. Has a brand new engine thanks to Walt Dupont. This truck was last on the road about 14 years ago. I'm going to get it in tip top shape mechanically and run the wheels off it for now.
CSArno is offline   Reply With Quote
Old 02-28-2016, 05:57 PM   #2
Barry-ct
Barry-ct's Avatar
Default Re: '49 F1 back on the road!
If you're ever down in the Hartford, Ct. area, I have some used engine pipes for a V8 and a extra muffler (new) and also a couple of NOSR tailpipes here. I also have a few frame hangers for the exhaust.
Barry
50 F-1
Barry-ct is offline   Reply With Quote
Old 02-28-2016, 11:44 PM   #3
mhsprecher
mhsprecher's Avatar
Great news. Congrats.
mhsprecher is offline   Reply With Quote
Old 02-29-2016, 01:55 AM   #4
FortyNiner
FortyNiner's Avatar
Always a happy day when you can put on road miles while creating some new family history. Enjoy the journey.
Old 02-29-2016, 04:32 AM   #5
big job
big job's Avatar
I'm in the same boat here's a 1950 my father bought new not restored just kept up.
The death wobble; if you have good king pins, tight box, drag, tie rod ends, I probably would look into especially rear spring hangers. Most like spring sag have them
re arched that effects the geometry ..
big job is offline   Reply With Quote
Old 02-29-2016, 11:26 AM   #6
TStiles
That first venture out is always something to remember - Great that you had three generations together to enjoy it!
TStiles is offline   Reply With Quote
Old 02-29-2016, 12:24 PM   #7
FlatheadTed
FlatheadTed's Avatar
Yes look into spring tension on the shackles ,Ted
http://www.flatheadted.com
Flathead Ted brake Floaters ,
Old 02-29-2016, 12:34 PM   #8
Harley Dean
Check the bushings in your front springs. They could be worn out, and have a slop in them.
Harley Dean is offline   Reply With Quote
Old 02-29-2016, 03:31 PM   #9
Walt Dupont--Me.
Walt Dupont--Me.'s Avatar
HI Christ. I'd put my money on the caster on the front axel, might have to put tapered shim under front spring perch to tip axel back. The book will tell you what caster should be. Walt
Old 02-29-2016, 05:06 PM   #10
FlatheadTed
With regular springs and not cross springs I would have to go with Walt ,we just did a chev with same issue
Old 02-29-2016, 06:26 PM   #11
CSArno
CSArno's Avatar
I will check all that. Thank you. There is 3-4 inches of play in the steering wheel before the tires move. It will need a rebuild regardless. Rebuild kits aren't cheap. Wow!
Old 03-12-2016, 07:03 PM   #12
CSArno
CSArno's Avatar
Went for another test ride today. Completely different truck than the last test drive. Rebuilt steering box, new king pins and bushings, new front spring pins and bushings, and all new tires. No death wobble! This truck now drives almost as good as my 2014 truck. I know someone is going to give me heck but I put Radial tubeless 225/75R16 on back and 215/70R16 on front on the original rims. Gives it a nice rake forward and looks good. I sealed up the rivet holes on the outside of the rims with POR. They don't leak a bit. Look forward to driving this truck ALOT more.
Old 03-12-2016, 07:43 PM   #13
Vanspeed
Vanspeed's Avatar
Feels great to drive an old ford that drives like a new one! Congrats! Now go use it and enjoy it.
Respecting and Resurrecting Ford Model A's.
Vanspeed is offline   Reply With Quote
Old 03-13-2016, 12:26 AM   #14
Fibber Mcgee
Fibber Mcgee's Avatar
I've always wondered about the "rides like a truck" reference, my 49 rides great as well.
Wanted, a car with a " Dynaflex Superflowing Unijet Turbovasculator which is Syncromeshed to the Multicoil Hydrotensioned Dual vacuum Dynomometer. "
Fibber Mcgee is offline   Reply With Quote
