04-12-2024, 09:51 AM | #41 | |
Re: NOS 8RT camshaft
Owner/Operator of 'Jailbar Ranch' on the side of Mt. Pickett. Current stable consists of 1946 1/2 ton pickup turned woodie wagon with FH V8, 1946 Tonner Pickup with 226 H six, 1979 Toyota landcruiser wagon, now wearing 1947 Ford Jailbar sheet metal. 'Rusty ol' floorboards, hot on their feet' (Alan Jackson) |
04-12-2024, 07:19 PM | #42 |
This link has info but I didn't see anything about the 8RT.
https://www.fordbarn.com/forum/showt...9029&showall=1 Some of the parts with odd prefixes are follow on replacement parts. The 8RT cam may have been a replacement for trucks. A lot of trucks had 8BA cams but after the EAB and EAC part change in 1952, the 8BA and 8CM parts were likely obsoleted so the later cams were called out as replacements. Sometimes they just made a new prefix for them. The EAB cam was designed to give a bit more torque than the earlier 8BA cam. |
04-13-2024, 12:10 AM | #43 | |
04-13-2024, 11:54 AM | #44 |
Boring & stroking an engine also increases the compression ratio as well. This will add more torque than cam swap. also consider NO 239 ci engine makes more than 80 HP in stock cindition, and this is with out generator and fan, JWL proved that/
Gramps |
04-13-2024, 05:27 PM | #45 |
I have never thought about that increased compression Ron. Longer stroke, larger bore but same combustion chamber. And it gets that right outa the chute! Or I guess you hot rodders say right off the line
04-14-2024, 09:03 AM | #46 |
04-14-2024, 11:42 AM | #47 |
Oh great, a new can of worms opens up, or is it Pandora's box? Next thing ya know, I'll be installing dropped spindles on the woodie. I actually do envision dual exhausts though, but I only have one old swingset frame in my pile, so might have to go single.
04-14-2024, 01:58 PM | #48 |
Save the swing set frame for the hillbilly paint booth like I got. Hang lots of parts!
04-14-2024, 11:28 PM | #49 |
Sounds like a good idea Skip. Truth be told, I wouldn't really want to skimp on the exhaust for this project. I have been enjoying working on this engine with the best parts I can come up with. So far I have found a lot of really good pieces here on shelves at the shop and online. I have NORS main bearings from The Barn's swap meet section, rod bearings from Van Pelt Sales, Gaskets from Olson's Gaskets,Cam bearings, reconditioned rods, and pistons and rings fitted by Wes at the machine shop. I have a friend here who runs a very well equipped auto repair shop which includes full custom exhaust service. Don't be too surprised if I have him bend something up for me. With all the help, direction and encouragement I have been getting here, I feel I'm really gonna have something that will stand the test of time. Thanks to all who have steered me in the direction of a high quality, if not all brand new, engine build. GB
