Old 01-31-2021, 02:47 AM   #41
Fortunateson
Default Re: Calling Ol'Ron, calling Ol'Ron...
The cam is a Max1 clone done by a local cam grinder who's been in the business since the mid fifties. The car will be a cruiser.
Fortunateson is offline   Reply With Quote
Old 01-31-2021, 10:18 AM   #42
tubman
tubman's Avatar
What kind of springs are you planning on using? Stock? New or used? When I got my MAX1 from Iskendarian, it came with a set of their 185G springs. I only needed a couple of shims and have been very satisfied with it's performance.
Old 01-31-2021, 12:01 PM   #43
flatjack9
flatjack9's Avatar
Lincoln Zephyr springs should be just fine
Old 01-31-2021, 12:01 PM   #44
51 MERC-CT
51 MERC-CT's Avatar
Just catch'n up on some Ol'Ron wisdom.
Old 01-31-2021, 12:14 PM   #45
Zeke3
Zeke3's Avatar
I just re-read my copy last week, my copy is spiral bound. I didn't have a dog looking over my shoulder either.
Zeke3 is offline   Reply With Quote
Old 01-31-2021, 07:05 PM   #46
Ol' Ron
Ol' Ron's Avatar
Lincoln Zephyr springs work just fine, but you have to buy them and a .060 shim os cheaper. I don't have the cash to buy something I don't need. Building an engine ?car is very expensive and aesthetics and brand names increase the cost with little benefit ot power or economy. I can't afford that. But I respect those that can. However, ther e are many people that buy things that just don't work for the application, just because it look good.
Gramps
Old 02-03-2021, 02:32 AM   #47
Fortunateson
As I mentioned earlier the springs will be new stock spec springs from Speedway. I'm now going to wait to have them checked before I get the .060 shims if indeed they are needed.
What does the 185G stand for?
Old 02-03-2021, 08:10 AM   #48
51 MERC-CT
51 MERC-CT's Avatar
Posted this some time ago, may or may not help clarify installed height.
Old 02-03-2021, 09:32 AM   #49
Ol' Ron
Ol' Ron's Avatar
That Book was printed 29 years ago, and I've learned allot since. I started Nostalgia engines and began rebuilding them for others for aprox 15 years. It was the first of the modern Flathead books and I think it helped bring the flathead back into popularity, When I went to the 1097 York ps car show there were only 6 flathead there including the one we brought. It was then I thought of writing my book, In 92 I brought a 100 books aand sold out in 2 days. I'm very proud of that.
Gramps
Old 02-03-2021, 10:49 AM   #50
tubman
tubman's Avatar
Ya know, I never thought about that. I always thought it was just a part number, but perhaps it does have some other meaning. I wonder if anyone else knows?
Old 02-03-2021, 10:57 AM   #51
flatjack9
flatjack9's Avatar
I always took it as just a part number and generally a stiffer spring than what is needed for a street flathead.
Old 02-03-2021, 03:00 PM   #52
Ronnieroadster
Ronnieroadster's Avatar
185G is the Isky part number for their performance type Flathead valve spring. That valve spring is similar to the Lincoln Zephyr valve spring which is a good alternative for the flathead.
Ronnieroadster
I use the F word a lot no not that word these words Flathead , Focus and Finish.
"Life Member of the Bonneville 200 MPH Club using a Ford Flathead block"
Owner , Builder, Driver of the First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921 in one and a half miles burning gasoline.
First ever gas burning Ford flathead powered roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH
Ronnieroadster is offline   Reply With Quote
Old 02-07-2021, 10:31 AM   #53
Brendan
Brendan's Avatar
Originally Posted by mfirth View Post
My opinion is to listen to OL'Ron .....
to bad Kids today don't listen to the old man at 53 i am the old man at work, when I say something they say I Know I know! keep your mouth shut and ears open!
If it would have been a snake it would have bit ya!
i can't spell my way out of a paper bag!
Brendan is offline   Reply With Quote
