Old 08-13-2017, 01:33 PM   #1
Bob56
Default 1936 Instrument dash light switch
Got all the lights working but the glove box clock. Now when I turn on the instrument panel light switch within seconds it feels like it is on fire. Is the switch going bad or is there another issue. If it is the switch were can I get one, I don't see them in any catalogs
Bob56 is offline   Reply With Quote
Old 08-13-2017, 05:38 PM   #2
JSeery
JSeery's Avatar
Default Re: 1936 Instrument dash light switch
Something is drawing a lot of current. Might try disconnecting one connection at a time and see if the problem area can be identified.
Old 08-13-2017, 08:13 PM   #3
JM 35 Sedan
JM 35 Sedan's Avatar
The switch contacts could be going bad or someone may have attached some extra lights or an accessory on to that switch circuit. No one is reproducing that switch to my knowledge in either the 36 or 35 configuration. It's possible that someone is/can rebuild yours or maybe you could do it yourself.
John
Old 08-13-2017, 08:15 PM   #4
2manycars
2manycars's Avatar
Wow, I did not know my 36 had an instrument light switch!
Bill
www.brauchauto.com
2manycars is offline   Reply With Quote
Old 08-13-2017, 08:47 PM   #5
1stford
1stford's Avatar
If I'm understanding the part description it's the switch that is under the dash and it turns the lights to your gauges on? If that is correct I just got a new one from Joes Antique fords in MA.
1stford is offline   Reply With Quote
Old 08-14-2017, 04:50 AM   #6
Bob56
Here is a couple of pictures. The switch is top left above radio. the other from under the dash. Also, how does it come out
Old 08-14-2017, 11:42 AM   #7
jfcrash
jfcrash's Avatar
As far as removal, gently squeeze the two metal arms on each side of the switch body together and you should be able to fenniest it thru the dash panel.
As far as heating, assuming its not an electrical wiring/cable issue, I had a situation where the two vertical electrical posts had to be separated with a thin piece of non conductive material... it seemed when I would pull or push the switch knob, the two vertical posts would touch enough to heat up where your two wires are connected.
hopes this helps, Jim
______________________________________________
jfc
I couldn't repair the brakes, so I adjusted the horn louder....
jfcrash is offline   Reply With Quote
Old 08-14-2017, 11:46 AM   #8
Bob56
Thanks. I will try that and see what happens
