05-31-2015, 10:33 AM | #1 |
Multi-meter tester
What does everyone use? Is a cheapo from Harbor Freight okay?
05-31-2015, 10:51 AM | #2 |
Re: Multi-meter tester
05-31-2015, 11:18 AM | #3 |
Fluke all the way. I have 2 different Flukes and a Klein.
Tod |
05-31-2015, 11:39 AM | #4 |
I'd agree that Fluke is probably the best, but for 95% of what you will be doing on your "A", checking for 6v, the el cheapo/sometimes free unit from HF is OK.
Besides, if some dimwit steals it, you arent out much. Good Luck |
05-31-2015, 11:48 AM | #5 |
A meter that has a mechanical meter movement (analog) works the best. The Model A electrical system has a lot of AC noise produced by the generator and ignition system. The AC noise causes the digital meters to "bounce around" and not have stable readings...where as the mechanical ones smooth out the noise.
Some of the more expensive digital models do reject the noise. I use an old Triplet Meter. Marc |
05-31-2015, 12:15 PM | #6 |
05-31-2015, 04:49 PM | #7 |
I bought a few at a flea market,$2.50 each.
05-31-2015, 07:41 PM | #8 |
I have fluke digitals at work which don't get interference because they are quality meters.
I also use the 6.00 sperry analog found on eBay I love using my digital power probe works great on the A systems and allows you to activate circuits by sending power and grounds etc. Also use a basic testlight for many things also on an A |
05-31-2015, 08:13 PM | #9 |
PO' folks have PO' ways!! OH, I just remembered, Bro Gregg's tool box has a DUDE Fluke in it, hope I kin find the instruction book & I hope it's in ENGLISH.
Dad W. (I collect old analog meters, buy new leads at Radio Shack & give them to Model A owners)
"THE ASSISTANT GURU OF STUFF" Last edited by BILL WILLIAMSON; 05-31-2015 at 08:22 PM. |
05-31-2015, 09:13 PM | #10 |
I use a fluke at work, but have used alot of those harbor freight wonder meters. Their slightly off but for a model A about all your checking is if 6V is present or checking if something is shorted or not...works great!
ive never noticed much bouncing and i use them on riding mowers or if it is slightly bouncing its not swinging wildly... im talking maybe .1V...
1929 Model AA - Need long splash aprons! |
05-31-2015, 11:21 PM | #11 |
I like analog meters for working on these old cars when running due to the unfiltered engine noise. Digital is fine for work when engine is off which I find most of the time.
