Old 11-07-2014, 08:27 PM   #1
FrankWest
FrankWest's Avatar
Default thinking of adding downdraft carb intake
Thinking of converting to downdraft intake with Stromberg 48 carb with air cleaner, circa 1934 on a model B 1933 engine. Planning to use an Ansen manifold.....
What problems could I have removing the oil manifold after 80 years and installing the new manifold. I know the stromberg 48 carb will have to be set up properly but I would hate to have physical problems removing the old manifold where I could need Drill and taping new studs. What are some common experiences. I don;t want to do more harm than good.
Some times old things that are working should just be left alone!
FrankWest is offline   Reply With Quote
Old 11-07-2014, 10:05 PM   #2
PC/SR
Default Re: thinking of adding downdraft carb intake
The Ansen should line right up, no drilling or tapping required. Beyond that it is just like installing any manifold. I use the copper gaskets. And it is likely that the old manifolds have been removed and reinstalled sometime in the past 80 years so don't worry about that. Go for it.
PC/SR is offline   Reply With Quote
Old 01-23-2015, 05:39 PM   #3
FrankWest
FrankWest's Avatar
The ansen has fins other intakes do not...
Should the intake be kept as cool as possible or be allowed to run hot?
Old 01-23-2015, 07:45 PM   #4
1931 flamingo
1931 flamingo's Avatar
IS YOUR CAR RUNNING NOW?? If so CONGRATULATIONS ! ! !
On the swap, soak the nuts/studs with a 50/50 mixture of Automatic tranny fluid and acetone, put on a few times, then SLOWLY try to back the nuts off.
Paul in CT
Old 01-24-2015, 12:27 PM   #5
PC/SR
The manifold will warm up with the engine and help atomize the mixture. A cooler mixture is more dense, but the atomization is needed for smoother running. I have a vintage Thomas with fins and it runs fine. I think the fins are more decorative than practical, though they will tend to keep the manifold from getting too hot up near the carb. The Ansen will run fine with fins.
Old 01-24-2015, 01:13 PM   #6
pat in Santa Cruz
pat in Santa Cruz's Avatar
in the unlikely event that the new flanges line up with the flanges of the old ex manifold, it would be a bolt on. However, if your new manifold will use the pre existing 2 bolts to attach to the heat plate, then odds are one or both will break off. You will have to deal with that. Also, odds are the flanges will not align, and the flanges on the bolted together unit should be surfaced for a good gasket fit. Its also probable that the rear ex port has sagged beyond the ability to line up the manifold for a leakless fit. In that case, you would be better off using a new ex manifold as well.
pat in Santa Cruz is offline   Reply With Quote
Old 01-24-2015, 01:23 PM   #7
Jim Brierley
On the 48- start with stock jetting, it should be very close to what you need. #48 main jets and 65 power jet.
Jim Brierley is offline   Reply With Quote
Old 01-24-2015, 05:21 PM   #8
racer32
I wish I could FIND an Ansen downdraft manifold.
racer32 is offline   Reply With Quote
Old 01-24-2015, 05:34 PM   #9
mshmodela
mshmodela's Avatar
Frank,
Welcome back to the Model A forum...
-Mike
Late 31' Ford Model A Tudor, Miss Daisy
I don't work on cars --I'm learning about my Model A.
Cleveland, Ohio
mshmodela is offline   Reply With Quote
Old 01-25-2015, 05:19 PM   #10
western77
western77's Avatar
Racer32 look at Reds Headers item no. 19.
western77 is offline   Reply With Quote
Old 01-25-2015, 06:05 PM   #11
racer32
Thanks! Any idea what it costs?
Old 01-25-2015, 06:19 PM   #12
waxhead
waxhead's Avatar
$165, quality is good, I bought one recently
http://reds-headers.net/index.php?ma...roducts_id=334
waxhead is offline   Reply With Quote
Old 01-27-2015, 04:57 PM   #13
Brian LI
Brian LI's Avatar
Ansen is a nice intake. We're currently running one with a Stromberg 81 carb. Takes s bit longer to warm up bu otherwise No issues.
Brian LI is offline   Reply With Quote
