View Poll Results: What head questions would you like to see on the market? | |||
Would you prefer/buy iron | 103 | 71.53% | |
Would you prefer/buy alum head | 15 | 10.42% | |
Would you prefer/buy both; | 24 | 16.67% | |
What combustion chamber shape would you buy crowfoot style chamber | 24 | 16.67% | |
What combustion chamber shape would you buy Heart style chamber; | 22 | 15.28% | |
Combustion chamber shape would give the best results. | 65 | 45.14% | |
What range of compression ratio would you buy, 5:1, | 18 | 12.50% | |
What range of compression ratio would you buy,6:1 | 78 | 54.17% | |
What range of compression ratio would you buy, 7:1 | 39 | 27.08% | |
What range of compression ratio would you buy, 8:1 | 17 | 11.81% | |
What range of compression ratio would you buy, 9:1 | 8 | 5.56% | |
What range of compression ratio would you buy, higher than 9:1 | 2 | 1.39% | |
Would you prefer/buy stock appearing head | 91 | 63.19% | |
Would you prefer/buy finned head | 35 | 24.31% | |
A water pump mounting | 124 | 86.11% | |
B water pump mounting | 16 | 11.11% | |
Multiple Choice Poll. Voters: 144. You may not vote on this poll |
08-13-2014, 08:16 AM | #1 |
New head options
Ok, I know it looks messy but please read through it before you check off items as there are A,B, Both kind of questions.
This is for a Winfield style head, not a stock Ford head. Please post a comment as to where you feel the spark plug placement should be and why, also please comment as to any other option/improvements you would like to see in a head. As you have guessed Tod asked me to post these questions. You will be able to answer for 30 days then it will close.
What's right about America is that although we have a mess of problems, we have great capacity - intellect and resources - to do some thing about them. - Henry Ford II Last edited by Mike V. Florida; 08-25-2014 at 11:13 PM. |
08-13-2014, 08:32 AM | #2 |
Re: New head options
Would love to see a correct Winfield or Super Winfield reproduced. Would also be interested in an accurate "police head".
08-13-2014, 09:06 AM | #3 |
Super Winfield Iron head would be good. Sorry, but don't know enough about spark plug placement to comment, but interested to hear others opinions on the subject
08-13-2014, 03:44 PM | #4 |
I agree with "gwhite" winfield super and good police.
08-13-2014, 04:13 PM | #5 |
I sent G an Excel version of my Winfield.
I also saved the images as jpegs and pngs. How do I post them? Tod |
08-13-2014, 04:22 PM | #6 |
08-13-2014, 05:01 PM | #7 |
Tod, here are the images...looks good!
08-13-2014, 08:09 PM | #8 |
Hey gwhite, thanks for helping and posting these images !
Hey Mike V... good stuff, thanks for poll. I do not see place for comments at bottom of poll, so here goes. Tod: Ed Winfield was acknowledged genius at A/B speed stuff..flatheads and OHV heads. His IRON heads are sought after...for their performance and durability. Winfield placed the plug between the two valves as in this picture...with the same comb chamber seen (as your image): This is picture of super Winfield (copy ?) at about 8.5:1 . Cragar also had a very successful OHV head with plug in (similar,but not exact) position between valves. So called hemi chamber had/has great success with plug placed between valves. PLUG LOCATION: So my choice would be that the plug be located approx. between intake/exhaust valves. Maybe a tad closer to exhaust if not centered. WEIGHT of head; very thick castings please! I suggest that you cast PLENTY thick iron in face of head, so that despite wear and/or unavoidable damage, the head can be milled/fixed safely with no worry regarding thinness of material and subsequent water jacket cracks happening. NOTE; I've owned a finned iron head that weighed 53 lbs and performed very well. However, IMO, that heads' comb chamber and plug placement was not ideal as Winfield. OUTWARD APPEARANCE; If you stay fathful to the Winfield iron heads basic outer appearance,i.e.- proud stud nut surfaces and WINFIELD script and number pad placement , I'd buy either SUPER WINFIELD AND regular WINFIELD copies. However, If you decide to make a (cooling) FINNED style Winfield/Weiand ....high and/or extra high compression ratios..I'd buy ! NOTE; Winfield made colored heads to denote high and higher comp ratios..we can do our own coloring if wanted, IMO. ACCESSORIES; I'd like to see a bung/threaded hole(s) at the rear of iron head to facilitate cooling hose attachment and/or temperature gauge attachment. Plus making provision for LARGE valve use without ending up with thin margins either gasket and/or thin head thickness. Time for nap..... Last edited by hardtimes; 08-14-2014 at 12:54 AM. Reason: .......... |
08-13-2014, 08:26 PM | #9 | |
Tod |
08-14-2014, 07:33 AM | #10 |
-WANTED-
Pre-War Speed Equipment Davies or Morrison Intake Manifold 77-6050B, 81AS - 81SB - 99AS - 99SB 19AS cylinder heads |
08-14-2014, 09:00 AM | #11 |
08-14-2014, 09:52 AM | #12 |
How many times are we allowed to vote?
that Winfield is the cats meow............ |
08-14-2014, 01:44 PM | #13 |
New quality parts are always a big plus in the A world.
Simplicity is the ultimate sophistication. L.D. I have 40 horses in the garage. Only feed them when I want to take them out. 31 Model A Tudor 55B Nick |
08-14-2014, 05:13 PM | #14 | |
From poll, looks like more than fifty already...or are polls deceiving ! |
08-14-2014, 05:41 PM | #15 | |
And it looks to me like 67 respondents. If there are that many interested I will begin cutting the pattern as soon as the other work in the machine and new patterns on order are cut. Probably looking at a month or so before I can get to it. Maybe I can have the basic pattern cut by Hershey time. No matter what, I will have pics posted here as I go along. I will cut one top pattern and 2 different combustion chamber patterns. Giddy up!! Tod |
08-14-2014, 08:05 PM | #16 |
Great news
08-14-2014, 08:55 PM | #17 |
The polls are favoring just what I was wanting. I hope to buy a 6.1 head to replace mine this winter. Count me in for an order.
08-14-2014, 09:59 PM | #18 |
I would think going with the B pump so as to get rid of the long bolts at the front and you could get more even torquing for all the studs. If I am gong to put a high compression head why would I want to hide it! Varoom
08-15-2014, 02:49 AM | #19 |
The Crows foot for sure, it was a better design that the later Winfield head. I think
he had to change it for patent reasons with Ricardo. The early one breathed better. |
08-15-2014, 03:04 AM | #20 |
Hey Tod,
Please take a look at the aluminum Winfield that I posted above and another look at the iron Winfield . Particular attention to the really wide gasket support areas of the alum head....BETWEEN cyls 1/2 , 3/4. Now look at the really narrow gasket support same areas of the iron head. VERY VERY important consideration ...is wide/sufficient gasket support in these TWO areas , particularly the higher comp ratio gets. |
