Old 01-17-2021, 11:38 PM   #1
Gold Digger
Default Rust in gas tank
I have 5 model A's at the present with one that has always had fine rust in the tank that I never have been able to keep cleaned out. In the past I would run an extension magnet to the bottom of the tank and clean what I could out but still would have the pencil filter to stop up and also the filter in the carb with real fine rust. This could be a trick everyone already knows but I came up with the idea to put a strong magnet with a small eye bolt screwed in it positioned on the bottom of the tank. About once a year I reach down and hook the eye bolt and pull out about a half a cup of fine rust. I used to travel about a hundred miles before having to blow back in the gas line to clear the pencil filter and maybe clean out the carb filter. Since I have been using the magnet I have never had to clean the filters. I know this may sound like a band-aid fix but it has worked for the last 5 years for me. Also I saw some magnets at Harbor Freight that would work that already have a loop made on top.
Gold Digger is offline   Reply With Quote
Old 01-18-2021, 12:31 AM   #2
Synchro909
Synchro909's Avatar
Default Re: Rust in gas tank
Have you considered trying a dirty leg to catch the rusty crap?
Old 01-18-2021, 01:20 AM   #3
McMimmcs
McMimmcs's Avatar
why don’t you just clean the tank properly once and for all and get Rid of the rust and the irritant or buy a replacement tank?
Old 01-18-2021, 07:40 AM   #4
WHN
If your car is a 28 or 29 it could be an easier fix than a 30 or 31.
We had the same problem many years ago on our keeper 29. The gas tank is not that difficult to remove. We than sloshed it twice. Making sure we took our time, and got the sealer everywhere.
It has now been over 30 years. Fingers crossed, we have had no problems since.
We also do not leave car setting with a tank full of gas. In the winter, we run it down to almost empty.
Go luck. Enjoy.
Old 01-18-2021, 07:43 AM   #5
Mike Peters
Mike Peters's Avatar
Synchro909's Avatar
What's a dirty leg?
Mike Peters is offline   Reply With Quote
Old 01-18-2021, 09:14 AM   #6
McMimmcs
McMimmcs's Avatar
Go luck. Enjoy.
I do the opposite, I fill them to the very top and add stabilizer / Seafoam.
Old 01-18-2021, 09:36 AM   #7
big job
big job's Avatar
This works 2 quarts of 3/4 stone some water and detergent and I put it in my cement
mixer and walked away. couple hours of that turn tank up side down let it run. Rinse and
repeat . Now pure steel nothing. You need the 3/4 stone cause its processed like sharp
diamonds..plus soap and water. not redneck but amazing results.
big job is offline   Reply With Quote
Old 01-18-2021, 11:05 AM   #8
katy
katy's Avatar
[QUOTE=Mike Peters; What's a dirty leg?[/QUOTE]
Sometimes called a sediment trap, like this:
Old 01-18-2021, 04:46 PM   #9
Synchro909
Synchro909's Avatar
Smile Re: Rust in gas tank
Thanks, Katy. That picture saved me a thousand words!
Old 01-18-2021, 05:28 PM   #10
SteveB31
SteveB31's Avatar
Evaporust can be purchased at Home Depot or Harbor freight. Buy 10 gallons. Fill the tank with it. It turns the rust into liquid and you drain it out. Works well. It is a product made to do exactly what you need. I have used it on many tanks with 100% success. Regarding off season storage, you are always better leaving the tank full of fuel. Rust occurs when the tank has no fuel in it, due to condensation and humidity. If the tank is full of fuel, it cannot rust.
SteveB31 is offline   Reply With Quote
Old 01-18-2021, 05:36 PM   #11
Kurt in NJ
Kurt in NJ's Avatar
I used to have the standpipe and pencil filter. -and would still have problems, took them out, filled and sloshed -- drained till most was gone, left the standpipe/filter out, went for a long drive and cleaned the filter every night, after about a thousand miles of driving there was no more accumulating in the filter.
Old 01-18-2021, 06:20 PM   #12
700rpm
700rpm's Avatar
Thanks Gold Digger. A simple inexpensive solution.
Ray Horton, Portland, OR
Old 01-18-2021, 06:57 PM   #13
PalAl
PalAl's Avatar
Originally Posted by Mike Peters View Post
Synchro909's Avatar
What's a dirty leg?
Here ya go, "Dirty Leg" info complete with pictures.....TADA
http://www.fordgarage.com/pages/kellyshutoff.htm
PalAl is offline   Reply With Quote
