Old 06-02-2020, 01:59 PM   #1
rosenkranswa
rosenkranswa's Avatar
Default Setting glass
I am replacing a broken drivers side window on my 1930 Town Sedan. I got the glass out in two intact pieces, which was not a trivial operation, and the lift bar at the bottom off. Using the two pieces as a template, a glass company is making a new piece for me using Triplex glass. Once I have the new glass back, I have to reattach the lift bar (which I’ve cleaned up and painted). What is the best way to do that?
Also, any tips on getting it back in place? Sure was a major pain getting it out of there.
Wayne @ Barb
Malvern
'19 T Speedster
'26 T Touring
'29 A Roadster
'30 AA Stakebed
'30 A Pickup
'30 A Town Sedan
'31 A Station Wagon
'38 Columbia Girls bike (WWII)
'40 Elgin Boys bike (WWII)
'42 Super Deluxe Tudor
'42 Willys MB Jeep
'43 Willys MBT Trailer
'43 M3A4 Hand Cart
'43 Harley Davidson 42WLA with sidecar
rosenkranswa is offline   Reply With Quote
Old 06-02-2020, 02:12 PM   #2
Ruth
Default Re: Setting glass
I used Tempered glass and glass setting tape from Bert's. https://modelastore.com/glass?product_id=6007
Ensure you replace everything that needs to be replaced while in there. You don't want to have to go back in there for a long time.
Ruth
Old 06-02-2020, 02:13 PM   #3
1931 flamingo
1931 flamingo's Avatar
Most vendors have glass setting tape that goes in the channel, then insert glass.
Paul in CT Most likely available where the glass is being cut.
Old 06-02-2020, 03:09 PM   #4
rosenkranswa
Just ordered a new Murray glass channel, bedding tape, and a channel kit as was suggested to replace everything in there. One thing that made it so hard to get out was an adhesive on the channels. Do they really need to have an adhesive put on them? I could see putting some on the top sponge to keep it I place.
Wayne @ Barb
Malvern
'19 T Speedster
'26 T Touring
'29 A Roadster
'30 AA Stakebed
'30 A Pickup
'30 A Town Sedan
'31 A Station Wagon
'42 Willys MB Jeep
'43 M3A4 Hand Cart
Old 06-02-2020, 09:11 PM   #5
Big hammer
On my 31 Tudor, the side channels had metal clips top and bottom that I reinstalled, I didn't use glue there but the sponge piece I did use glue. The glass in the side channels hold the channels in place when the glass is up or half way up, when down the channels don't move the clips hold them tight. At least for me.
get a bigger hammer tap done
Old 06-04-2020, 09:29 AM   #6
Bob Bidonde
Bob Bidonde's Avatar
When I replaced the glass in both windows of my Victoria using a non-adhesive glass setting rubber, the glasses pulled-out of the riser channels while going down. There was enough friction in the side window channels to make this happen. So my not so brilliant solution was to bend the riser channels for a more snug fit of the glass. WRONG! Both door window glasses cracked.
In disgust, I went to a glass shop with experience in fitting windows into street rods. The shop owner gave me an education about setting window glass, and he uses a setting tape material with adhesive on both sides so the glass stays put.
I also have set glass using black silicone, but I find this to be a messy technique, and the silicone squeeze-out is hard to remove from the glass.
Bob Bidonde
Bob Bidonde is online now   Reply With Quote
Old 06-04-2020, 04:59 PM   #7
midgetracer
midgetracer's Avatar
I have had real problems using the neoprene stuff that the vendors sell. I wish they would sell cork/fabric like I am used to getting.
midgetracer is offline   Reply With Quote
Old 06-04-2020, 05:40 PM   #8
burner31
burner31's Avatar
A nice rubber head mallet works real good for setting the glass in the channel
PS...Use the setting tape
Keith
Shawnee OK
'31 SW 160-B
