Old 11-03-2020, 06:38 PM   #1
bosticjb
Default Headlight Seal
anybody got any pictures of proper placement of headlight seals for a 28 A
bosticjb is offline   Reply With Quote
Old 11-03-2020, 07:32 PM   #2
Gary WA
Gary WA's Avatar
Default Re: Headlight Seal
cork gasket pushes into channel in reflector
www.whidbeymodelaclub.com
Old 11-03-2020, 08:31 PM   #3
bosticjb
Thanks
Old 11-03-2020, 09:18 PM   #4
Ranchero50
Some 3M spray adhesive helped hold them in place for me.
Building a '29 Speedster, the hard way...
Ranchero50 is offline   Reply With Quote
Old 11-06-2020, 11:49 PM   #5
redmodelt
redmodelt's Avatar
The split goes at the bottom so moisture can drain out.
Old 11-09-2020, 10:54 PM   #6
bmg1959
I had to carefully trim my cork gaskets down thinner with a good sharp razor knife and still fought to get them in.
Typical fit for most reproduction parts.
bmg1959 is offline   Reply With Quote
Old 11-10-2020, 08:01 AM   #7
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Man, ...you went about it the hard way!! Since you are in to the wood scene, just clamp both pieces in-between two pieces of wood and use some clamps to compress the cork. After 15 minutes or so, when you can remove it the cork will remain compressed for more than enough time for you to insert it in the channel.
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 11-10-2020, 11:08 AM   #8
ericr
ericr's Avatar
won't it pop out down the road if you open the cover?
ericr is offline   Reply With Quote
Old 11-10-2020, 11:17 AM   #9
BRENT in 10-uh-C
Nope.
BRENT in 10-uh-C
